Protecting Cab Rear Window
Cab owners,
Ordered a Cab “Window Pillow” from Mid America Motorworks (Tweeks). Looks like a pillow in the catalog picture but what actually arrived was a 4” dia “sausage”. We’re only talking a $15 item, but I just want to know if it will do as good a job of preventing rubbing as one would expect a wider pillow to do. Is the OEM Fleece for the Boxster any better?
Appreciate input from anyone who’s tried different methods to protect their rear window from scratching or creasing.
Thanks.
Thanks.
Stormy - I have no clue, but from my experience, ANY material - including micro fiber - will leave marks on the window. I can imagine a scenario where the pillow is vibrating (rubbing) and will leave marks as well.
PLUS, dosen't this make putting the top down a two person job, one to hold the switch and one to keep the pillow in place as it goes down?
Fred
Fred
I have a new top (since January) and already have on crease/point on the left side where the top contacts it each time it's lowered. Since I don't always use the cab boot (lazy) I know I won't use any pillow. I was pissed off at first but have accepted it.
I have been using "Lemon Pledge" on my window to reduce the chance of scatching. Mine tends to scratch where the top material makes contact with the folding window.
Dave
Dave
I am about to replace my top. I have been wondering if putting a tint or film on both sides of the window will protect it - thinking that the tint can be replaced easier and cheaper than the window. Anyone tried this?
Originally Posted by Korny993
FB where are you purchasing your new top. Are you doing the install yourself??I ask because I am about to go down the same road and a DIY is out of the question.
You do not post your location so I don't know if this is realistic for you or not.
My top was replaced 3 years ago. I don't use any pillow. I treid a terry towel for a while but didn't think it was worth the effort. I use a microfiber towel to wipe the dust off before I lower the top (and I ensure the window folds well when I put it down. I usually have to stop mine after it's 75% open to give the top a tug to ensure I don't pinch the fabric with the pins. At that Time I ensure the window is folding nicely and then finish dropping the top. I use the boot 95% of the time.
I use Meguiar's plastic cleaner and polish on my rear window and it does a great job of removing the scratches. After 3 years it still looks like new (or at least close to it).
Tom,
I do the same, dust first, open it over halfway and karate chop along the fold then lower rest of the way. My goal is to put the boot on all the time.
Sounds like preparation will do more than any pillow being jammed in there.
What is the specific issue with the pins? They look menacing, but what actually happens to cause damage? What piece of the top are you tugging?
Thanks for all the help.
The pins will cause wear on the top when they hit it (not to mention the top doesn't go down all the way). I tug on the top right at the level of the roof's support bar (which also ensures the bar flops into the proper place).
