993 Forum 1995-1998
Brake Pad Sensor
Old Feb 22, 2003 | 08:24 PM
Kristoffer's Avatar
Kristoffer
Question Brake Pad Sensor
I just installed new brake pads & rotors thanks to Robins Web Site. Robin You ROCK!!!! <img border="0" alt="[cheers]" title="" src="graemlins/beerchug.gif" />
But I am having trouble with the brake pad sensor. Of course I broke some but I'm having trouble with one that just seems to big!! I installed the pads then went to slide it in & it just will not go in. Am I suposed to put it behind the pad before I put the pad in or is there another trick?
Old Feb 22, 2003 | 08:45 PM
Paul M's Avatar
Paul M
POACB
Post
Kristoffer,
If you are referring to the piece with the spring that fits into the pad, you need to attach it to the pad before installing the pad in the caliper.
Old Feb 22, 2003 | 09:16 PM
Edward's Avatar
Edward
Addicted Specialist
Post
Or a better alternative still: forget about the sensors altogether! The pads are so easy to check through the spokes, and if you DE at all, you'd be in there bleeding brakes anyway. I ditched my sensor wires (just wire-tied them back out of the way) at my first pad change almost two years ago and haven't looked back since....just my opinion, FWIW
Edward
Old Feb 23, 2003 | 01:05 AM
Ray Calvo's Avatar
Ray Calvo
Passed On
Wink
From Edward </font><blockquote><font size="1" face="Verdana,Tahoma,Arial,Helvetica,Geneva">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Or a better alternative still: forget about the sensors altogether! </font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">I did a similar mod, only I cut off the sensor at the wires just downstream of the connector, stripped the two wires, then connected them with a wire nut. The pad thickness is downright easy to check with a flashlight looking in at the inner side of the caliper even with the wheels in place.
Old Feb 23, 2003 | 01:08 AM
STLPCA's Avatar
STLPCA
Addict & Guru
Post
</font><blockquote><font size="1" face="Verdana,Tahoma,Arial,Helvetica,Geneva">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Originally posted by Edward:
<strong>... haven't looked back since....</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Edward
That's good. 'Cause if your brakes go, it's not what's behind you that matters.
Kristoffer
In your post are you referring to the brake sensor (length of wire w/a connector to the outside edge of the brake pad) or the anti-squeal discs that fit into the pistons & affix to the back of the pad?
BTW, if you decide not to use the sensors, note they have a normally closed circuit, so be sure the 2 wires to each sensor are connected or you'll have a warning light.
Old Feb 23, 2003 | 01:59 AM
Kristoffer's Avatar
Kristoffer
Post
[/qb][/QUOTE]
Kristoffer
[/QB][/QUOTE]
The brake sensor. I didn't have any trouble with the anti squeal.
FYI I am not using OEM pads, but there is a space for the sensors.
Old Feb 23, 2003 | 03:48 AM
Mike J's Avatar
Mike J
Post
I agree with the other guys...just cut off the end of the old sensors, solder the wires together, use a heat-shrink cover on it, and tie-strap it to the strut. I did this so that I could replace with real sensors if I wanted...not cutting of the wiring or the plug on the strut. I found the old sensors were junk anyways...they were corroded into the pads and I had to cut the wires to remove the pads!
Its been working fine for a few years...this is for people who actually check their brake pads once in a while!
Cheers,
Mike
Old Feb 23, 2003 | 01:01 PM
STLPCA's Avatar
STLPCA
Addict & Guru
Post
Kristoffer
Unlike the others, I have retained the sensors. I'd guess your problem is the aftermarket pads are not notched properly. I've had no problem fitting the sensors to oem Textar pads.
Ray's suggested "fix" will work fine to avoid a light if you can't get the sensors to fit the pads & you can always go back to the sensors w/your next pad change.
