993 Forum 1995-1998
Air through the door handle
Old Feb 19, 2003 | 11:59 PM
strangegobbler's Avatar
strangegobbler
Question Air through the door handle
Maybe this has been discussed before - if so sorry.
I like to ride around in the cold weather with the sunroof open and the heat on. It give me a little feeling of being out in the elements.
Unfortunately, when I have the sunroof open and the windows closed, I get a massive amount of cold fresh wind blowing in through the door handle. It was 35 the other day, and that's enough to freeze my leg. Has anyone else had and solved this problem? I haven't yet pulled the door off, but I'm thinking some creative insulation might take care of the problem.
Thoughts?
Old Feb 20, 2003 | 12:11 AM
Wreck Me Otter's Avatar
Wreck Me Otter
Post
Here you go:
911
Door Panel - Air Leak
1/97
7059
10/21/97
Binder-Service Technical Bulletins
Air Leak at the Door Panel
Vehicle Type:
911 Carrera (964 and 993)
911 Turbo (964 and 993)
Model Year:
As of Model Year 1989
Concern:
Air drafts in the area of the inner door opener.
Modification:
As of April 1, 1997 from VIN: 99 1VS322950
From the above-mentioned VIN a felt piece is installed in the inner door opener (Figure 1). This significantly reduces air drafts from the area of the inner door opener. The felt piece may be installed in earlier vehicles.
Repairs:
Installation of felt piece.
- Disconnect the door opener rod, inner door cover and pull handle.
- Lay felt piece onto the inside of the inner door opener, and mark with a pen or suitable marker (Figure 1).
Important : The pointed part of the felt piece must point forward in the driving direction.
- Apply glue on the marked area of the inner door panel and install the felt piece.
- Reinstall the pull handle, inner door cover, and the door opener rod.
Important : Avoid damaging the felt piece by carefully pushing the door opener rod through the slot in the felt (Figure 1, arrow).
Parts:
993 555 715 00 Felt
Old Feb 20, 2003 | 12:44 AM
Mark in Baltimore's Avatar
Mark in Baltimore
Post
Kim, you da man! When I bought my car, I noticed this nasty draft when the sunroof was open but not when it was closed. Thanks for the update.
Old Feb 20, 2003 | 08:37 PM
strangegobbler
Post
Zowie, SB! That was only 12 minutes to get a detailed and useful description of how to fix the problem.
You are 'da man' - Many thanks.
Old Feb 20, 2003 | 08:43 PM
Anir's Avatar
Anir
Post
Nicely done, Kim - the TSB man!
Mike, forgive me for asking, but why do you call yourself "strange gobbler". I can't get my head around that nickname.
Old Feb 21, 2003 | 12:29 AM
strangegobbler
Post
Anir-
I'm a Virginia Tech fan, and maybe a little off-center. For those of you that don't know, VT is "Home of the Fighting Gobblers"...
Anyway, it's usually impossible to find a unique name with 'Mike' in it, so strangegobbler works.
Go Hokies! (the other more common nickname)
Old Feb 21, 2003 | 12:31 AM
YellowC4S's Avatar
YellowC4S
Post
so is that like there's a TSB on it and I can just take it up to a Porsche dealer and they will take care of it no charge?
Old Feb 21, 2003 | 12:48 AM
Anir's Avatar
Anir
Post
Mike,
Thanks for the explanation. Sort of like us Wildcat fans "bleeding blue".
Sorry to be nosy.
Old Feb 21, 2003 | 09:12 AM
Caveman's Avatar
Caveman
Wink
Hi Mike,
Sorry to pry but are you , and your fellow football fans, aware of the sexual connotation of your name? Maybe it's just a British thing?
Before you ask, I was called Captain Cavemen at school because I shared a terrible temper with my cartoon namesake.
Cheers,
David
<img border="0" alt="[cherrsagai]" title="" src="graemlins/drink.gif" />
Old Feb 22, 2003 | 03:17 AM
pwrsurg's Avatar
pwrsurg
Post
My wife's 97 Boxster has the same problem. It seems like the fix would be similar, yes?
Old Apr 12, 2005 | 08:05 PM
joolsbourne's Avatar
joolsbourne
Default Air through door handle
Can anyone help me with this problem. Air comes in through the drivers door handle but only when the sunroof is open. I have taken off the door panel and can't see anything wrong, ripped or missing.
I have found a related link but the answer seems to be missing?
https://rennlist.com/forums/showthread.php?t=14486
What was the answer and why can't I see it????
Old Apr 13, 2005 | 01:14 AM
jkuniverse's Avatar
jkuniverse
Kim,
Thanks for the answer...but I can't see the photo. Can you upload the picture(s) again? Thanks.
Old Apr 13, 2005 | 08:28 AM
joolsbourne
I can't see the photo either, re-upload would be much appreciated.
Am I going mad? Was that answer there when I posted??????
Old Apr 13, 2005 | 10:45 AM
swftiii's Avatar
swftiii
Kim - I too would like to see the picture as I have the same problem.
strangegobbler - I am also a Hokie fan - Class of '93, back when winning a couple football games in the entire season was a bonus. My last year there was the first time we beat UVA in a really long time and their first appearance in a bowl from their break.
Go Hokies!
-Skip
Old Jan 3, 2010 | 12:58 PM
Quadcammer's Avatar
Quadcammer
Anybody actually done this tsb? I'm wondering if the door panel needs to be removed as the terms used are a bit ambiguous.
Thanks.
