Top Brake light
Top Brake light
Hi
Two bulbs of my top brake light were broken. I decided to replace them by home made assembledLED's documented in the attached pdf
Hans
Hans
VladiD (08-05-2024)
Hi Hans,
Thanks for the read!
The article is unclear as to where to connect and how to mount the resistors so a little ingenuity by the installer will be required.
Tore also offers a similar fully assembled solution:
https://www.bergvillfx.com/products/...-3rdbrakelight
Here is a safety upgrade that can be added once an LED lamp array is installed:
https://993servicerepair.blogspot.co...h-mounted.html
Have a great day,
Andy
ToreB (08-07-2024)
Andy,
Each bulb is replaced by a combination of a LED and a series resistor. I soldered the resistor of 620 Ohm to the cathode of the LED.
does this answer your question/remark?
Hans
Hans
pp000830 (08-08-2024)
Many years ago I tried similar resistor/LED-solutions, but over time the solderings failed due to vibration. The third brake light is especially exposed to vibrations when mounted on the "basket handle" or any kind of rear spoiler.
The below has proved to be much more sturdy solution.
Cheers,
Tore
Cheers,
Tore
Hi all
There are many solutions, I choose this one.
It takes some time to de-solder the old bulbs and assemble the LED-Resistor combination but as a retired engineer I have time enough. Total costs were approx $12
Time will learn how long it lasts
Hans
Hans
