Shock tower tool in Seattle area
Location: Lat: 47 Deg 26.848N Lon: 122 Deg 21.341W Seattle
I am going to install the PSS-9s and the TRG sways mayself...is there any one in the Seattle area that has the "open" socket for the shock tower nut that I may borrow? It is the one that enables the hex wrench to be used at the same to keep the shaft from spinning. I have air tools but would rather use the correct tool. Are there any other special toos? This is all I can remember from reading the DIY info from Robin's site.
Also, somebody mentioned cutting a 15/16" spark plug socket to do the same thing. What did you use to cut the socket with?
This sounds like an interestining project to DIY and I am looking forward to some good garage time!
Check this out, these are the tools I used when I lowered my 993. Look for avillena response. Enjoy. If you need more clarifications about the tools email me.
Andrew
96 TARGA blk on blk 6 on the floor
https://rennlist.com/forums/showthre...spension+tools
Andrew
Hey Andrew,
Very clever! I can do that as I have a socket with the hex on it hanging around in the toolbox.
Any other tips or recomendations are welcome!
If you have an impact wrench, the nut will come right off w/o that special tool. You can use it to tighten the nut also, just make sure it is not set for too much torque when tightening.
15/16 plug socket
The nice thing about this is that you don't have to cut anything. The socket has a place on top you can grip with a crescent wrench and a hole through the center to run the 7mm hex.
Re: 15/16 plug socket
How do use use a torque wrench with this method?
I tried to approximate the torque setting by working sort of backward. Instead of holding the shaft with a hex and torqueing down the nut, I put the torque wrench on the hex for the shaft (measuring "loosening" torque) and went from there. Didn't actually go to the regular spec since I figured there had to be some resistance tied up in the shaft's rotation.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Re: Re: 15/16 plug socket
see this link for an example:
http://buy1.snapon.com/catalog/pro_d...re&dir=catalog
I used crows foot to torque the socket. I also used an allen bit, 7mm, with 1/4 extension and 1/4 rachet, this way you have a good hold on the center shaft.
Andrew
96 TARGA blk on blk 6 on the floor.
Andrew
I obviously didn't explain this fully.
So the torque wrench is attached to the allen bit via an extension. Then as you try to either rotate the shaft and hold the nut in position, or tighten the nut, holding the shaft in position, torque is applied to the shaft, through the allen bit, along the extension, to the torque wrench - and you measure it. Is that any better?
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Tom,
It is not that tough to do a DIY on the PSS9s. Many of my customers put it on themselves. I also have a little tip sheet for the PSS9 install for things that are not covered by Robyn's DIY, so if you send me your email address I will be happy to send it to you. Armed with the proper instructions and the support of the people here I am sure you can do it.....
