Another Oil Temp Question
Sorry I wrote so much without any real answer to your question ;-(
Bob
It's on top of the crankcase in front of the engine, that's why you don't see it. It's shown on the manual (at least in my paper manual).
Without "snake hands" you pretty much need to take the intake off in order to get it.
The naysayers say (cute twist of the language), the Cargraphics cooler can't work...and if it does happen to cool the oil, it will severely compromise your air conditioning. I for one am very interested in the Oil temps Kary sees at California Speedway this weekend. And if Kary is a real sport and wants to put the naysayers to bed, once and for all, he will do a run session with his air-conditioning on...come on Kary, do it! Let us know how it goes. Personally, I will sacrafice a little air conditioning for cooler engine oil...but then again, my 993 is not a daily driver, and I live in San Diego with pretty mild weather.
At Streets of Willow 2 weekends ago, with a Turbo S cooler helping out in the oil cooling department, and ambient air at about 95 degrees F, I was seeing 10:00 o'clock on the oil temp gauge. I would rather see below 9:00, just as the old SC with an auxiliary cooler would run on hot days at the track. The SC oil temps would get up to about 215 degrees F, max! And that is at Willow Springs in the Cali High Desert with ambient air at about 100 degrees.
I may weaken one of these days and at a minimum, get the Cargraphics dual Turbo S system. Stay cool!!!
You propose an interesting test. I am perfectly willing to run the air conditioning in a perfectly warmed up car in the grid, but as I understand it running the air conditioning at high engine RPM's for 30 minutes is not good for the air condition parts. This is just something I was told by some racing folks that saw someone run their car's air conditioning on the track with some less than optimal results in the engine compartment.
I have many bench marks written down for California Speedway with varying outside temperatures/oil temp readings so I will be able to match my test conditions up with this new CG oil cooler. It will be interesting to see the results this weekend, but as I said just doing basic tests on the street and driving school show significant improvement.
That is somewhat normal if you have the stock oil cooler only. Since I installed the additional oil cooler cruising in town or on the freeway never gets above 8 o'clock. I can't wait to try it on the track this weekend! Will you have time to come up to the speedway this weekend to visit?
First, this is probably not as much of a help for high-speed track use, but for street situations I am extremely impressed with the results of the manual oil cooler fan switch mod as per Robin's site. Flick on the factory-looking 944 switch in the center console, and within 60 seconds or so the oil temp gauge reading is back to 8:00.
Second, anybody familiar with Thermostrips? They are "irreversible temperature indicators" which record the highest temperature reached on a given engine surface. This might be a quick way to get a sense of maximum temperature with minimal hassle--just stick it on and go.
Now you might say that the ambient temps were so cool that this experience is not relevant, but I'll tell you that I drive frequently in cool weather as well as in 90 degree weather (which is why I needed the Cargraphics cooler in the first place) Even with these cool ambient temps, I've never seen ANYTHING like this level of cooling. It was amazing, and I have no doubt that this cooler will make a huge difference. I am also eager to see what it will do to my AC function, but for me, this is secondary.
I'll also report through the upcoming season, but as has been reported here before (and the reason I slid further into the abyss), this is the answer to oil cooling.
Chuck
Here's wealth of information:
http://p-car.com/diy/fan/
Also, have you verified your fan resistor if it's working properly? Most common problem is a dead resistor which prevent the cooling fan from running it's slow speed. It is designed though to still work in the fast speed, for safety, but at that point your temp indicator is already at 930 position.
