A/C compressor replacement?
Came back from Europe after 3 years and a war... to find out a few things wrong, including a seized A/C compressor. Boy, does that belt smoke a lot when the clutch kicks in...
So, is it possible to unseize it somehow or is it better to just buy a replacement? I vaguely remember that a Denso compressor should work, did a search and found this one: https://www1.rockauto.com/en/moreinf...eT1Y8TdsrEEGpd Is that the right part? How hard is it to replace, what is needed, if anything?
Thanks in advance!
Thanks in advance!
I have replaced the compressor on my1988 911G which is very similar to the 993. Most recently bought a remanufactured one from Denso and replaced the drier too. You'll want to do that with the 993 then have the system evacuated and refilled with R134 refrigerant. The job shouldn't take much more than a couple of hours and you'll likely want to replace the belt too.
Thank you. Any specific tools for compressor replacement or did the shop do it? Also, any way to un-seaze the existing compressor, at least for a while?
The compressor should be a pretty easy swap. The hardest part is likely the hard lines. I'd say 10 mins to get it out. Then you'll need to recharge the refrigerant. Easy day. Double check the seals while you're in there.
So, the question I still would like to get ideas on - is it possible to un-seaze the compressor and how does one try it without breaking open the lines?
Hi Nile13,
A seized compressor could release some metal bits into the system, and cause more serious problems, such as clogging the expansion valve. I wouldn't try to get it going again. Keep you finger crossed it hasn't already released shrapnel.
I would replace the compressor, then take the car to a good AC shop to have the system evacuated and recharged. They should know how much oil to put in the system.
The compressor is a Denso 10PA 15C, widely available--try to get one that has the clutch and correct pulley already mounted.
There are five bolts in a vertical position that hold the compressor in place, three on the left and two on the right. When you are removing the bolts on the left side, the second one from the rear is left in place, no need to remove it. When I reinstall a compressor, I wear a thin rubber glove on your right hand, with a tiny magnet in the tip of one finger, to help hold the big square nuts while re-threading the long bolts.
I find it easier to put the belt on the compressor by rotating it a bit clockwise (viewed from the top), then rotate it into mounting position.
Some years ago, I had a seized compressor on my 1983 911SC. It threw the belt, and I replaced the compressor, had the system evacuated and recharged, and all was well. Hopes yours turns out the same.
GJSPIN (07-24-2022)
Thanks, Bobby! Sounds about right from memory of replacing belts before. I'm just a bit surprised that the compressor seized when the car was in 22-month storage. Since it has not turned, I don'tthink there's any metal in the lines, right? Just don't clearly understand what the reason is for that kind of seizure
As far as compressor - do you thik the Denso referenced above is the right one with the right pulley and clutch?
Another problem I have is the heater fan fuse keeps popping. Either immediately or after a very short period. So I need to see what's going on with the two cabin fans.
That's true, haven't thought about this. I also need to figure who in Boston area is capable of doing A/C work on this car. Nobody comes to mind. Any suggestions?
