993 Forum 1995-1998
My car unlocks itself
Old 05-24-2022 | 03:00 PM
doridori's Avatar
doridori
Question My car unlocks itself
This problem just happens to my 1998 993 C2S:
Whenever I tried to lock the car, it will unlock itself automatically.
Is this a common problem for 993? What exact part that needs to be replaced?
Old 05-24-2022 | 03:24 PM
Matthew So's Avatar
Matthew So
Are you posting on the correct forum? 2008 911 should be 997...
Old 05-24-2022 | 03:33 PM
doridori's Avatar
doridori
Sorry for the typo. The year is 1998. I just made the correction. Thanks
Old 05-24-2022 | 03:48 PM
Matthew So's Avatar
Matthew So
I don't personally experienced this but looks like other have posted in other forums:
http://forums.pelicanparts.com/porsc...ay-locked.html
https://www.porscheclubgb.com/forum/tm.aspx?m=1025314
Good luck!
Old 05-24-2022 | 10:44 PM
pp000830's Avatar
pp000830
Hi Dori,
I seem to recall if one of the doors is ajar when using the fob to lock the car it will lock and then quickly unlock the doors.
Andy
bobbyp (05-24-2022)
Old 05-25-2022 | 04:07 AM
ToreB's Avatar
ToreB
Most probably a failed door or lock position switch.
The alarm/door lock control unit contains fault codes that will reveal the reason for this. A Porsche-compatible OBD tool will be able to read out the codes.
Cheers,
Tore
Old 05-25-2022 | 11:28 AM
drodg's Avatar
drodg
My 96 993 does this periodically. I think it might be the same issue. I go to lock the doors and it immediately unlocks. I have thought I was holding the button on the fob down too long. Maybe something else is wrong but it doesn't do it all of the time.
Old 05-25-2022 | 05:58 PM
mike cap's Avatar
mike cap
I had this issue years ago and it was a failed door lock actuator. I replaced both sides and it silver the problem.
Old 05-26-2022 | 12:36 PM
jay@EZimmoblock.com's Avatar
jay@EZimmoblock.com
Basic Sponsor
When you lock with the FOB, does it sound like the actuator is moving full stroke or something less? On my 97, if I open the door and try to lock with the FOB, the actuators make a "dull thud" sound instead of the more pronounced sound of a successful lock. Obviously your door isn't open but a failed door jamb sensor could be telling the alarm unit it's open.
Quick Reply: My car unlocks itself
