Center console delete project finished
Hi folks! Just want to share the project I have been working on for quite some time.
I really like the spartan look of older Porsche interiors and wanted to replicate some of it in my 993. This has no practical purpose and is only done "for the looks". Also, I wasn't going after weight savings. Just a mix of nostalgia with creature comforts for daily driving. There is no standard aftermarket solution available, so I decided to design and fabricate my own. Below is the result of my trial and error and learning and redoing. There are a few more things I want to change, but it mostly looks the way I envisioned.
Few comments regarding the approach:
- I mated the back half of the original center console with the front half I designed and fabricated. I printed the front part using PETG in 3 pieces to fit into my 3d printer's build volume. The front and back are connected using bolts. Some bondo was applied to hide the print lines and the whole contraption was reupholstered. You can still see some unevenness in the areas where the parts are connected.
- The "shifter gate" is laser cut out of aluminum and painted with self-etching primer. It looks reasonably well but doesn't hold to occasional bumps from gear changes. I will need to find a better solution. Powder coating? Anodizing?
- OBD port is relocated to the driver's side of the front far corner of the new console and is easily accessible for maintenance.
- The two left switches on the dash are wired to control the radio: volume and track selection. I never need to touch the stereo itself because I play my music from the phone via Bluetooth. Now thinking of it I should have saved the glovebox space and moved the stereo somewhere even farther away.
- Happy to share the 3d model and give some guidance on how to replicate this if someone is interested. But be warned, it's very far from being a simple bolt-on. Also, it's not reversible and requires a fair amount of cutting of the original parts both metal and plastic.
The following 2 users liked this post by 90decibel:
KingTubby (04-24-2022),
rs911porsche (04-24-2022)
Very unique! My suggestion is to use black screws.
enjoy in good health!
paul
paul
Clever mods and I like the vibe you are going for.
Not sure what would be best for repeat contact with the lever sliding back and forth. Powdercoat v anodized but the finish on anodized usually looks finer. Depends if you trying to match the finish on the parking brake recess, footplate or dash console...
i think the bump would bug me...
Nice one.
Nice one.
Nice one.
Nice one.
Congrats for accomplishing what you were after. It takes a bit of getting used to,and having the radio in the glove box is interesting. Your Porsche, your car. Full respect.
I really appreciate the thinking behind this and your effort to make your car "yours". While there is something to be said to keeping it all original, lets face it, a lot of 993 interior elements are very obvious, clunky attempts to polish up the older platform it was designed around. I would love to see a console like this in brushed stainless, with a compliment of more hard surfaces and less leather.
Looks like you spent a lot of time and at least a few dollars to come up with an answer to a problem that didn’t exist. You really molested the interior of the car and made it less functional and fugely besides. Too bad someone didn’t talk you out of butchering up the interior.
Full steam ahead its your car and project after all who says we know anything haha , B
I’m not sacrificing virgins here. I bought the cheapest air cooled Porsche in the country. It was in a rough shape. Just trying to restore the car to its former glory mechanically, make it look slightly different and have fun in the process ✌️
90decibel (04-24-2022)
