993 Forum 1995-1998
Focus 9 Tech Solid State DME Relay
Old May 23, 2021 | 11:45 PM
Jbelt01's Avatar
Jbelt01
Default Focus 9 Tech Solid State DME Relay
After reading all about the infamous DME relay I’m going nuts trying to figure this out. I ordered a solid state DME relay from F9 thinking it would be more reliable than the OE mechanical. Good preemptive maintenance.
The first F9 solid state relay immediately energized the fuel pump when inserted and ran constantly - even when the key was not in the ignition. Thinking it was defective I asked for a replacement.
The second F9 solid state relay did not immediately energize the fuel pump, but when I attempted to start the car, it would turn over and stumble a bit before stalling. I tried several times to start the car, but again it would turn over and stumble a bit...then stall.
I insert the old school DME relay - fires right up instantly without hesitation and runs strong. Return to the F9 solid state - turns over and seems to fire momentarily but won’t idle.
Has anyone run into these electrical gremlins?
Let it be known that F9 sent me a replacement relay without me needing to return my existing relay. Top notch customer service. +1
Popular Reply
Jun 10, 2021, 01:31 PM
Ftech9's Avatar
Ftech9
I just wanted to give everyone an update.
I can confirm that a recent update to the SSR design resulted in a compatibility issue with the 993. To my knowledge, other models are not affected. I thought this change was minor, but obviously that was not the case. The purpose of this change was to correct outlier issues that affect a fraction of a percent of customers. During my 5 years in business, I have had several thousand SSR customers. On rare occasions, I have run across issues where the SSR works when the mechanical relays do not and vice-versa. It has always been my goal to achieve as close to 100% compatibility as possible.
As an immediate remedy, I have issued full refunds, including shipping, to anyone who has experienced this issue. I have also reverted all current stock to the original SSR design. So far, every customer I have refunded has agreed to test an updated SSR when it becomes available. I believe I now understand what the root cause is, and I have designed two potential updates. The first update is intended to be a fundamental correction to the original SSR design. I expect it will resolve all issues including issues with outlier vehicles. The second design is based on the upcoming Solid-State cooling fan relay for the 944 and 968. This design is overkill by any measure, but it is also simpler to implement compared to the original SSR. The only draw back is significantly higher cost. I intend to send all three SSR versions to every customer who had an issue for evaluation. The customer can choose which version they would like to keep at no cost.
I expect all test SSRs to go out late next week. If anyone has any questions, concerns or comments, please to not hesitate to contact me directly at joe@ftech9.com.
Joe Baumbach
Old May 24, 2021 | 12:01 AM
Gbos1's Avatar
Gbos1
.......and why I just stick with the Porsche OEM DME Relay and keep a spare OEM DME in the glovebox. Not the first I have heard of this.
Old May 24, 2021 | 06:53 AM
tstafford's Avatar
tstafford
There’s another recent thread on this same topic. I’ve been a F9 DME owner, supporter for a good while. It’s disappointing to hear people are having bad experiences.
Old May 24, 2021 | 09:13 AM
SpeedyC2's Avatar
SpeedyC2
I am in no way discounting the issue you are having; all I can report is about four years using a F9 relay in my 944S2 and now about 5 years in the 993 without issue.
Old May 24, 2021 | 09:43 AM
Jbelt01's Avatar
Jbelt01
It’s bizarre. It won’t run correctly with either of my 2 F9 relays, but no issues with the Porsche relay that came with the car. I ordered a new Porsche DME relay which should be here shortly. If I can plug-and-play using the new Porsche part I should have my answer.
I’m going to ship the F9s back, so maybe they can figure out the anomaly.
Old May 24, 2021 | 09:55 AM
71-3.0-911's Avatar
71-3.0-911
I'm curious as to what the answer is here. I've been running the pump prime version for about 2 years now with zero issues. I do still keep a backup in the glove box though.
Old May 24, 2021 | 10:07 AM
Tlaloc75's Avatar
Tlaloc75
I plugged mine in, and on the third drive the car died mid-corner while pulling g’s. I coasted off onto the narrow shoulder and replaced with my oem spare. Car fired right up. F9 sent me a replacement right away, so I’ll see if that does better.
Old May 24, 2021 | 01:12 PM
pp000830's Avatar
pp000830
For me, the phrase "preemptive maintenance" seems a lot like looking for love where some enterprising vendor will find her for you and she has the potential to become an expensive and unrewarding date.
It Falls under the 993 Service and repair mantra:
Grant me the serenity to accept the things I should not upgrade,
the courage and knowledge to fix the things I must,
and the wisdom to know the difference.
We all feel your pain as we have all been there.
Andy ;-)
7 Porsche Models That Have Aged Like Fine Wine
Old May 24, 2021 | 03:44 PM
SpeedyC2's Avatar
SpeedyC2
Andy ;-)
I generally agree with Andy's mantra whole-heartedly. In the case of the DME relay, however, I had two OEM relays fail on my 944S2 in quick succession, so decided to try the solid-state version. It was flawless through a number of years and many DE events.
With that experience in hand, I bought an F9 relay when I got my 993 and installed it right off, keeping the original in the glove box as the back up. 5 years later I have had no need for the backup.
Still, it is a bit unsettling others have been having issues. It would be nice to hear feedback on the cause from F9, if anyone gets any.
Old May 24, 2021 | 05:21 PM
boomboomthump's Avatar
boomboomthump
Well that is the same person who started this thread. He posted his issue last week in my thread about "pump prime" vs "non-pump prime" versions.
That said, Tlaloc75 posted just above that he also recently had an issue. Aside from these two, have not heard of anyone previously having a problem. Seems they've been bullet proof for others.
Old May 24, 2021 | 05:55 PM
AOW162435's Avatar
AOW162435
Seared
I've had the pump prime version for a few years now - no issues.
Andreas
Old May 24, 2021 | 06:10 PM
Tlaloc75's Avatar
Tlaloc75
F9 said they would do an analysis of the relay and see what went wrong. Maybe electrostatic damage? Won’t know till they get it and have a chance to investigate.
Responsiveness on their part was 100%.
Old May 24, 2021 | 06:53 PM
Ftech9's Avatar
Ftech9
Hi All,
I am aware of this issue and will do everything in my ability to find a solution. I have a few theories why this might be occurring on this specific 993 but not others. At this point I am waiting for the two SSRs to be returned for evaluation. If Jbelt01 is willing, I have several SSRs planned with specific controlled changes to test these theories. Once I have identified a root cause, I expect to be able to enhance the design to be tolerant of this condition.
Joe Baumbach
Old May 24, 2021 | 07:17 PM
sdm100's Avatar
sdm100
Mine has been bulletproof
Old May 24, 2021 | 07:20 PM
Tlaloc75's Avatar
Tlaloc75
Originally Posted by Ftech9
Hi All,
Joe Baumbach
Mine’s in the mail on its way back to you. You should see it soon!
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
