valve stem seals replacement with engine in
Anybody knows whether it's possible to replace valve caps(usual source of exhaust smoke on start-up/after idling) without dropping the engine?
It seems to be possible for older 911s: http://forums.pelicanparts.com/porsc...stem-seal.html,
it seems to be possible to replace valve springs on 964 https://rennlist.com/forums/964-foru...tml#post668514
But what about 993?
But what about 993?
Make sure you have identified the true cause of your smoke at startup as there are multiple causes and the valve guides leaking is not the first one on the list.
The main reason is oil vapor vented from the oil tank condensing on the interior surfaces of the intake manifold and then this oil is ingested at startup. If the oil is overfilled just a little the problem is accentuated.
Hope this helps,
Andy
Hope this helps,
Andy
M. Schneider (05-19-2021)
aam993,
Thanks for the insight.
Once again I'm a little confused about the terminology. All I could find on "valve caps" was in the picture below and it seems our engines do not have them.
I did make the assumption that the original poster was speaking of the guides as these are often sighted as a root cause for oil leaking into the combustion chamber. I am clearly not an expert at internal engine componentry but looking in the PET exploded parts view how would one avoid having the valve stem slip down the rabbit hole once the collet is removed to replace the valve stem seal? Is there a special tool for this?
I also found the definition of the stem seal:
"Different than other seals in the engine, valve stem seals play an important role in lubrication. Valve stem seals allow a controlled amount of oil to lubricate the valve stem as it moves in the valve guide. The amount of oil that passes by the valve stem seal must be precisely controlled."
Over the years I have only heard debate about worn guides contributing to oil consumption never the seals, is there a functional reason why they are not a potential root cause in our engines, or was this cause simply overlooked and the seals were just replaced when the guides were during a top-end rebuild.
Sorry for all the questions but inquiring minds want to know as they say.
Andy
Andy
I have used it on small block chevy’s, but not these engines.
The following 3 users liked this post by red64chevelle:
quick search on youtube nets this video of a new stem seal being installed:
http://forums.pelicanparts.com/porsc...ml#post4831341
Why folks assume worn guides, commit to top-end rebuild with engine out in presence of oil leaks I don't know.
To OP, similar to other 911's the valve seals can be replaced with the engine insitu , but it's tedious. As someone else mentioned, you'll need the an air adapter for compressed air to keep the valves seated while removing the spring and retainer to get to the seal. You'll need a valve spring compressor to work in tight space. Be sure to stuff every crevice with a rag to keep the retainers from dropping somewhere you can't reach them. I would be sure to have a couple extra retainers on hand. Tedious.
I happen to have an extra set of new Porsche brand valve stem seals...pm if you're interested
pp000830 (05-19-2021)
thank you 95_993 for confirmation. Sent you pm regarding the seals too.
Yes, keeping the valves up with compressed air makes sense.
Do you happen to know what valve spring compressor works for our cars?
For older 911 there is https://www.pelicanparts.com/More_In...pn=PEL-TOL-P7E and https://www.pelicanparts.com/More_In...pn=PEL-TOL-P71. Will they work for 993 engine?
Smoke on start up would likely be lower exhaust valve seals since not a lot of oil sits up too and they see less heat.
Lowers are definitely easier.
uppers have very little room for compressor with cam towers in place. You may want to call pelican if they will work.
More room around the spring for a tool On lower springs
Very tight on the upper springs. You’ll need to research to find a compressor tool fits.
Here is the clearances for the tool on the upper springs. You may have to search a little for a dial type compressor that will fit.
Great, thanks for the pictures.
Did you have to use special tool 9237 (https://www.search-vehicles.com/deta...675386587.html) for seal removal and/or special tool 9569 for installation? These are mentioned in factory shop manuals for valve seals.
Mine were quite worn at 27k miles. While it didn't smoke you could see tell tale signs the valves was not seating properly on the seats.
As for the two tools listed on Pelican, I don't think they will work. Even if you were able to use a stud temporarily on the valve cover bolt hole to mount the compressor, I am not sure the spacing is right. might be worth a look or a call to pelican.
Here is is mounted on earlier 911 and you can see the location of valve cover hold down.
I'd look for a small overhead valve spring compressor with a dial to compress axially,. They are fiddley but you can likely get the job done with one on the lower exhaust valves.
As for the other tools mentioned, they are easier to work around. Getting the old seal out is easy if you're not worried about damaging it with pliers. Getting the new one on and seated just requires a cutting a piece of thickwall plastic or copper tubing with an i.d. just over the dia of valve stem to push it down to seat it. To stretch the seal over the stem, a small piece of thin plastic that wraps around the circumference of the valve stem, rolling the outer end a little tighter to pass inside the valve seal and allows you to slide over the stem, removing the plastic sleeve.
heliolps2 (05-19-2021)
You could use the threaded foot from the pelican tool and make a small plate with a couple stand-offs, tap a hole for the threaded foot. Sorry for the rough sketch.
