power steering belt replace
How does one change the power steering belt? Do you need to reomove the pump? Having trouble removing the top right spark plug wire from the plug. Do I need to remove the power steering pump?
Look at this site: http://p-car.com/diy/sparkplug/
You do not need to remove the PS pump. It's a PITA to get to that last plug, but not really a big deal after you've done it once before and know the system.
There's also great info in the shop manuals.. What's that you say? Your working on your car without a copy of the shop manuals???
I took a look and could see a sliver of the belt. It seems to be turning when the engine is on. What's the next step in determining a loss of power to the power steering? I am not leaking fluid either, BTW.
is it making any noises? If the pump side was bad you hear it surely.
One of the seals inside the rack? Is there a seal between high pressure input and return?
Did you check the fluid level and remove the front under plastic to make sure it wasn't puddling up there?
I have replaced a pile of these, both with the engine in and out, and have not found a defective belt yet. Some were worn, but not ready to split (unlike the distributor belts I have seen..)
I see that Keith found some missing teeth on his car, which is interesting.
It is a bit of a bear to replace this belt, but its easier with a lift, but still cramped. Ideally, you should only have to loosen the pump on its mount by removing the bolts on the belt side, that would allow you to tilt the pump up to fit the new belt on, but unfortunately the belt itself is in the way to tighten those bolts. Clearly a design not allowing for servicing!
Cheers,
Mike
Cheers,
Mike
It sounds like the next step is to pull the rack to make sure the seals are good, which involves about $30 of Pentosin CHF202. Before I flush that, is there any way to verify high pressure within the line?
Does your power steering work? Can the wheels be turned relatively easily while the car is stopped? (try doing it with the engine off to see what that feels like - heavy!).
I have not flushed the fluid by removing the lines on the rack - but have thought about it. Is that your intention?
Cheers
MIke
Not sure why you are doing that - you can check the seals by visually looking at the rack - no leaks, seals are good.
Cheers
MIke
Cheers
MIke
If I were to remove the rack to take apart and investigate, that would likely cause me to lose the 1.5 qts that are already in the system. I'm not talking about a simple leak, I'm thinking there might be a catastrophis failure of a seal within, and not necessarally one that seals the inside of the rack from the outside of the rack. There is no indication other than the lack of power assistance and a slight hiss if the wheel is being turned. No noise, no obvious leaks.
Ahh, got it, thanks!
I wonder if the alignment guys put a lot of twist on the rack itself when adjusting things? That twisting could have screwed up something internally in the rack causing binding?
I hope that you got back to the alignment shop and discussed why the tie rod disconnected - assuming you put it on correctly when rebuilding, that is another pointer to some rotational force being put on the rack itself. I have not taken one apart (yet), are their guides or bushings that keep the rack from twisting?
Anyways, it does sound like a disassembly is required - please get back to the forum when you are into it and find the issue, it would be good to know.
Best of luck!
Cheers,
Mike
Best of luck!
Cheers,
Mike
