Front Lift Points
Front Lift Points
I have a 1995C2 that I need to lift with my hydraulic scissor lift. The rear lift points are clearly defined but not on the fronts. Could someone please point them out to me. Do I need to remove a panel?
Right behind the front tires
I also use these aluminum lift pucks on all 4 corners with my lift. Fit the factory lift points nicely. No affiliation.
https://www.ebay.com/itm/2-X-Porsche...QAAOSww7tbyzri
shimmey (09-17-2020)
I think I saw somewhere on this subforum that you can buy/install reinforced jack points
dave
95 C2
03 540i6
84 380SL
I suggest using the lifting pucks as well. They ensure you are on the correct lift points and provides some space between the body and your jack points. I bought a set from a Rennlister and think everyone should use them. Most importantly when you go to a tire shop it ensures the techs place their lifts in the correct locations.
here is the ones I bought. RRC
https://rennlist.com/forums/market/1178596
