993 Forum 1995-1998
Accellerator pedal (aluminum)
Old 03-16-2004, 12:51 PM
OldGuy
OldGuy's Avatar
Default Accellerator pedal (aluminum)
Me and my buddy were going to CNC some
pedals and I got a good idea on the clutch
brake and dead pedal but the accelerator
is plastic? does the al pedal just screw on to it also??
Does that Accel pedal come out easily so I can let him
have it for a week?
DO you have to drill your own holes for the pedals
when installing? It appears to be the case. No biggie
just wondering.
Old 03-16-2004, 02:50 PM
nile13
nile13's Avatar
OG, be very careful of dead pedal. I now have a Rennline pedal laying here and _there is no way_ it will work in my cab. The angle is all wrong, it doesn't sit flush to the floor or perpendicular to my foot. Pelican lists it as a pedal for all 993s and 964, but it simply ain't so. I'm more confused now than I was a few weeks ago.
If someone has a good close-up of _any_ dead pedals in both coupe and cab, please show them.
Old 03-16-2004, 03:02 PM
adsc4s
adsc4s's Avatar
Mike, can you return it? I got the set from Gert and the deadpedal fits flush with the floor. I haven't had a chance to take a pic yet.
Old 03-16-2004, 03:11 PM
nile13
nile13's Avatar
I got it from a private seller, but I can sell it on eBay, no problem. I still very much want a dead pedal in the car, so I'll let it lay here until I figure out what fits and why. I used to be an engineer. At this point it's just an experiment
If you have a chance, please make a pic of yours installed. If there is a good pic of it before installation, I'd love to see it as well.
Thanks!
Old 03-16-2004, 03:32 PM
Mark in Baltimore
Mark in Baltimore's Avatar
Mike,
My Rennline dead pedal fits perfectly. I can't imagine theres a different pedal box between coupes and cabs, but you never know. I bought mine about two years ago; perhaps the design changed?
Old 03-16-2004, 04:32 PM
max911
max911's Avatar
i am waiting for my rennline deadpedal from pelican.
judging by the part numbers, the pedal that fits our 993s is the same as the '89 and older cabs/targas. (the '89 cab/targas had extra steel reinforcements in that area compared to the coupe's, hence the difference)
i will post a picture once i get it....and if it fits
Mike, i also have a rennline pedal for the >89 coupe....i'll take a comparison photo so you can see if it is what you have.
max
Old 03-16-2004, 06:19 PM
KeithR3
KeithR3's Avatar
Mike,
I got my pedal set from Renn-Line too and it fits perfectly. My car is a coupe.
Old 03-16-2004, 06:49 PM
nile13
nile13's Avatar
Mark, I'm not sure now, but I think the design might have changed.
Max, Keith, pictures would be greatly appreciated. If you tell me which pelican number you got, that would help too.
The reson I need pics is to compare the left side of the pedals. Mine is flat with two mounting holes, I think I saw some that were "lipped out" at an almost 90 degree angle.
So far I'm hearing "fits well" comments from coupe people. I was thinking that teh floorpans of coupe/targa/cab should be the same in 993, but the creeping doubt is forming as I type this.
I hope to figure it out and maybe put it in an FAQ, since the issue seems to be unresolved for others as well.
Old 03-16-2004, 07:24 PM
User 4621
User 4621's Avatar
Here's a pic of mine. The dead pedal fits and feels great, and it screws in down by the floorboard, so no need to punch holes up where the pedal actually sits. The gas pedal is a full replacement including the hinge. I also have the gas pedal extension in this pic, which both raises the pedal and brings it closer to the brake, allowing easy heel-toe. The whole set is from Rennlist sponsor AJ-USA.
Old 03-16-2004, 07:30 PM
nile13
nile13's Avatar
Peter, two questions:
1. Is it a 90 degree bend, or less?
2. Does it screw through the side piece?
Bonus question - does dirt/sand get behind the dead pedal?
Thanks!
Old 03-16-2004, 09:56 PM
Dudley
Dudley's Avatar
Mike,
I bought the AJ dead pedal and it did not fit in my Cab either. Though, I have heard coupe owners had no trouble.
Dave
Old 03-16-2004, 10:04 PM
nile13
nile13's Avatar
Dave, do you still have it and/or can you discribe why it did not fit?
The plot thickens.
Old 03-16-2004, 10:10 PM
User 4621
User 4621's Avatar
Less
Yes
No
What do I win?
Old 03-16-2004, 10:22 PM
nile13
nile13's Avatar
We shall see, Pete. You've definitely won something. I'm looking around feverishly. Oh, I can FedEx you a snowball. We got about a foot of this stuff today
Old 03-16-2004, 11:16 PM
Dudley
Dudley's Avatar
Mike,
When I pulled back the carpet there was no notch in the floorboard that the pedal was made to fit into. The meeting point between the floor board and inner wheelwell was a tight fit. When I placed the dead pedal in the obvious position, it was 5/8 over the vinyl rest pad. I trimmed it down and though it fit better, it was not really functional. Tossed it.
The Tip Cabs must be a bit different.
Dave
PS: The piece I bought was identical to PeterS' except black in color.
Quick Reply: Accellerator pedal (aluminum)
