Trouble removing front bumperettes
I'm trying to get my front bumperettes off. Removed cap and got 1 nut off, but the other 3 wont budge using the same allen wrench. Guessing they havent come off in 24 years so maybe rusting on. Hit them with some WD40 and letting sit for a while, but anyone else had similar issues and found a solution? Kinda hard to access them but was debating trying a nut extractor next - if i can find one that will find on an extender wrench.
+1 on the PB Blaster. Hit it 2-3 days in a row so that it gets good penetration. I think 8mm is correct, but you may have trouble getting a regular socket to fit into the opening in the bumperette. I seem to remember that my regular deep well socket wouldn't fit and having to use a thin-walled socket out of one if my Griot's kits.
Like Half German said, hit it with some PB Blaster and let it sit overnight. Then take a deep 8 mm socket and give it a good whack or two with a hammer to break it free. Then try to loosen the nut.
