993 tips?
993 tips?
Good to meet you guys.
I recently got hold of a 993 C2 tiptronic (around 25k miles). I am sure these questions has been asked a thousand times,
but I figured I would rather have an up-to-date advices from active forum members.
Here are some questions:
1. The car came with 265 40 18 rear which was rubbing fenders a lot so I changed to 265 35 18 PS4.(front PSS)
The car now drives like front and rear axle have different ideas about cornering. Is this mainly due to difference in tire compounds or alignment issue?
I never had this issue using two different compounds on E92 M3 drift cars so I wonder if the new rear tires just aren't broken in,
or whether it is a peculiarity of being RR layout.
2. On incline, it seems sometimes engine doesn't really want to start, but drives fine once it starts. I have checked battery voltage it was fine.
Is the starter motor a common failure item?
3. I was surprised the transmission responds to button inputs fast for a 23-year-old car. There is, however, a weird half-clutch lockup in 2nd gear whenever I try to accelerate hard in 2nd. This does not happen when I shift near the redline from 1st to 2nd. Is this some programming issue that can be rectified with a flash?
4. Engine oil. M1 0W40 or 5W50?
Pic here.
Pic here.
IMHO
a) check the suspension and bushings, alignment is recommended
b) not really clear on that but i would check on your compression rates for the cylinders (was a late issue with my one)
c) sounds really wired, but when was the transmission oil changed the last time, new oil brings often much improvement
d) depending where you're located or of what time in the year your driving, 5-10W50 better, check the search function here, there's a lot more info around
cheers
cheers
Hi S85B50,
The Tirerack specified tire for a 993 is Front Size:18" 225/40-18 Rear Size:18" 265/35-18
This may have something to do with it.
Also, the 993 needs to be aligned by someone who knows what they are doing as it has what is called a Kinematic toe adjustment on the rear axel that only a very few shops other than a dealer have the special tool to set it and even among those who have the tool fewer know how to use it. If the rear is out of adjustment the car will do just as you describe.
I would get an alignment at a shop or dealer who knows how to align a 993 and see if your problem goes away. If not and your suspension when inspected seems to be in order to put the proper tires on the car and try again.
Replace the DME relay sometimes called the fuel pump relay, a known problem with an internal solder joint can cause intermittent starting problems.
Beyond these new caps/rotors and clean the idle valve on top of the engine can help..
I have no experience with this. I can tell you way back when the 993 was built the only "flashing" one could do in their Porsche involved clothing or more rightly the lack thereof.
Oil brands and viscosities can be a very contentious subject here on Rennlist so here is what Exxon Mobil says and what I use:
From the Mobil 1 Web site: "Based on what you've told us, your vehicle manufacturer recommends Mobil 1 FS 0W-40 viscosity and oil that meets Porsche A40". The manufacturer has factory filled your vehicle with Mobil 1 oil and also endorses Mobil 1 as the service fill oil.
The most important aspect of oil on a 993 is to not inadvertently overfilling it. A common happening with serious consequences. Here is how I change the oil on my 993:
Oil & the 993
Hope this helps,
Andy
Oil & the 993
Hope this helps,
Andy
Regarding 3 - agree with others, this is normal. IMHO, the tiptronic is worthless in auto mode. In auto mode it always starts out in 2nd and shifts way too early. Shift it manually and it will preform much better. I would also dump the tip steering wheel with the buttons on it. They're ugly and it is too easy to hit them by accident and red line the engine. Lastly, IMHO, the shift plate look bad. You can get a shift boot and install it in its place and it looks so much better. The search function will keep you busy for hours. Welcome to the madness.... and please... more photos!
