993 Forum 1995-1998
White smoke from exhaust...
Old 03-17-2002, 11:55 AM
993RS
993RS's Avatar
Exclamation White smoke from exhaust...
I drove my car extensively over the weekend, and I had noticed that when the Porsche garage filled up the oil, they were really down to the minimum. So I added half a quart of oil last night. Today, when I drove, I noticed a cloud of smoke coming out of the exhaust and fumes coming in through the ventilation vents. Turned around and went home. Later, I noticed a small puddle of oil near the right wheel. I definitely did not add too much oil! I wonder if when they re-assembled the car, the oil level control somehow was not done right, and resulted in too much oil being added in the first place, so that when I added the half a quart it was too much. Will take it to the garage first thing in the morning, but in the meantime, any other ideas? Thanks! (Rats, it meant no driving around today... <img src="graemlins/cussing.gif" border="0" alt="[grrrrrrr]" /> )
Old 03-17-2002, 03:45 PM
Viken
Keeper of the Truth
Viken's Avatar
Post
Sounds like someone (you?) spilled a little oil on the exhaust manifold/heat exchanger. It will burnout eventually.
Old 03-17-2002, 03:58 PM
Bins
Bins's Avatar
Post
When this happened to me it was the lower gaskets that leaked, the oil fell on the exhaust manifold and then burned up causing embarrasing white smoke.
Doubt if its that otherwise they should have noticed it, though if it is, no biggy.
Old 03-17-2002, 04:09 PM
STLPCA
Addict & Guru
STLPCA's Avatar
Post
[quote]Originally posted by 993RS:
<strong>I added half a quart of oil last night. ...I definitely did not add too much oil! I wonder if when they re-assembled the car, the oil level control somehow was not done right, and resulted in too much oil being added in the first place, so that when I added the half a quart it was too much.</strong><hr></blockquote>
Phil
Are you judging level by the dash guage <img src="graemlins/nono.gif" border="0" alt="[nono]" /> or the dipstick ? If the former, you may have inadvertently overfilled. If the later, and your dipstick level is correct, I'd go w/Viken's conclusion, or (hope not) a leak.
BTW, oil smoke is generally a blue tint (& smells like ... burnt oil), water vapor is generally white. A little white smoke is nothing to worry about - unless the garage stuffed a water pumper back there.
Old 03-17-2002, 07:58 PM
Flying Finn
King of Cool
Flying Finn's Avatar
Post
Phil,
I'm with Viken here, how carefully you filled the oil..?
I once did similar thing w/ my veteran 911 (1975) and was worried when I saw smoke outside the car (can't have it inside since I don't have heating, or A/C for that matter ;-), but when I saw oil was dripped to the exhaust, I stopped worrying & drove harder, after that day, no smoking anymore, it had all burned out.
Old 03-17-2002, 08:08 PM
993RS
993RS's Avatar
Post
OK, thanks. I may have spilled a few drops... Will see tomorrow. I admit that I went by the dash guage, but I only check the dipstick once a month. The dash gauge has been pretty reliable. The car was really hot when I first looked at the guage (before deciding to add some oil), and saw that it was really still pretty low (just barely above the red with the engine idling...). <img src="graemlins/c.gif" border="0" alt="[ouch]" />
BTW: What I forgot to add, even though I spilled maybe a spoonful, the puddle near the right wheel was about almost an eighth of a drinking glass... So I am still uncertain... Also what would happen if too much oil were added? Does it spill out somewhere?
Old 03-17-2002, 09:46 PM
STLPCA
Addict & Guru
STLPCA's Avatar
Post
<strong>Also what would happen if too much oil were added?</strong><hr></blockquote>
Just like us, when it's overfilled, it feels nauseous & throws up. That's the most likely explanation for your problem. Go check the dipstick.
Old 03-17-2002, 10:15 PM
Randall G.
Randall G.'s Avatar
Post
<strong>****snip***
Does it spill out somewhere?</strong><hr></blockquote>
When it happened to me (thanks to an in-op oil cooler fan = much higher operating temperature ), it blew the oil filler cap off. Probably happened while I was idling on an incline. Friggin' oil everywhere ....
Old 03-17-2002, 11:22 PM
Kai 96 993
Kai 96 993's Avatar
Post
[quote] When this happened to me it was the lower gaskets that leaked, the oil fell on the exhaust manifold and then burned up causing embarrasing white smoke.
<hr></blockquote>
same here, i had mine on the left though
Old 03-18-2002, 07:06 AM
993RS
993RS's Avatar
Post
Well, this morning when I calmed down (I was really excited this weekend believe me... ), I opened up the engine lid and immediately saw that in the lower right hand corner there were traces of oil... My face began turning red, because I saw what must have happened...
I still went to the Porsche garage and had the engine, underside and the tray cleaned out, which solved the problem. I'd rather not say what happened, but I bet you all can guess... (after 20 years 911, but I was really awfully excited... <img src="graemlins/cussing.gif" border="0" alt="[grrrrrrr]" /> )
Thank goodness, I turned the star rating off...
Old 03-18-2002, 12:15 PM
Bins
Bins's Avatar
Post
glad it was only that. DOH! <img src="graemlins/c.gif" border="0" alt="[ouch]" />
Old 03-18-2002, 12:23 PM
Robin 993DX
Lifetime Member
Robin 993DX's Avatar
Post
Phil,
There is no mystery as to what happened. You over filled the oil and you possibilly parked your car on a slight incline and the overfilled oil came out of the oil filler opening in the engine bay and it dripped down to the exhaust and there are probably some left over oil on the engine shroud rubber seal too.
Old 03-18-2002, 12:44 PM
Radar
Radar's Avatar
Post
Perhaps, the oil filler neck should have been painted yellow? One way to be sure and not miss it.
Old 03-18-2002, 12:46 PM
Robin 993DX
Lifetime Member
Post
[quote]Originally posted by Radar:
<strong>Perhaps, the oil filler neck should have been painted yellow? One way to be sure and not miss it.</strong><hr></blockquote>
Nagh...
That would be way too ricer.
Old 03-18-2002, 01:21 PM
Ray Calvo
Passed On
Ray Calvo's Avatar
Wink
Like the others, I think you were just a stupid moron and overfilled the tank. Have done it myself on older 911s; topped it to near the full mark on the dipstick with engine at normal street temperatures, then went to track and promptly got the engine GOOD and hot. There is an overflow on these tanks, it dribbled down on right side of engine creating a nice mess and a 200 point increase in my blood pressure. This was on a '84; feel 993 is similar.
Hopefully, from your description that's all it was.
Probably not a bad idea to do a "recalibration" check of the dipstick (uhhh, the one on the engine?) against the oil level gauge. Good luck, and happy driving with Tweetie!
Quick Reply: White smoke from exhaust...
