Toe in mm please...
Toe in mm please...
Hello, Can someone help me know what the toe values are in mm instead of minutes for front and rear?
Need help with alignment because the alignment machine the shop is using is in mm.
thanks!!
thanks!!
depends on what you want for toe
zero in front is just zero
I've read -1.3mm each side in the rear is good
and have used it and been happy.
if you still need a specific conversion 911slow posted a page of them here
https://rennlist.com/forums/porsche-...nt-values.html
but you might need to be a paying rennlist member to view the thread.
Front toe depends on street or track use, tire size/grip, front:rear balance, etc. But for street use keep it simple with 0 toe.
Rear static toe has to be set in consideration of rear tire (i.e. 265 or 285), rake, rear toe control arms (rubber = compliance vs. heim joints that allow more precision and hence lower rear toe settings), kinematic settings, perhaps most important - driver preference re. balance and how 'free' a rear end you want.
1.3mm toe-in each side with stock rear toe control arms (rubber) is good starting point but keep in mind that is usually paired with a bit of negative front toe.
Received 5,416 Likes
You just can't beat good toe.
https://robrobinette.com/ConvertToeDegreesToInches.htm
Then just convert inches to mm.
For your tire diameter go to Tire Rack, find your tire, and go to specifications.
Hope this helps.
G
Using inches or mm to measure toe is idiotic and your shop should be ashamed to be such idiots. And you should tell them that.
Biggest problem is this: at what point are they taking the measurement? If they're measuring at the wheel lip, then you don't calculate the inches or mm using the tire OD, but instead the wheel diameter. And so the conversion depends on the wheel size or tire size or whatever they're measuring. Yeah, it's freaking idiotic and only idiots use that. Degrees is the correct measure for normal-IQ people.
What machine are they using? Newer Hunter machines allow switching of units of measure between degrees (fractional), degrees and minutes, mm (at reference diameter), etc.
The online calculator I posted above does use tire diameter.
I really don't know because I've been doing my own alignments on my autocross 993C2 for over 10 years using the SmartStrings set, https://www.smartracingproducts.com/smartstrings.html (no affiliation, just happily using their alignment tools).
Using strings for the toe settings, I measure in fractions of millimeters. I made the conversion from degrees to mm the first few times but now I don't even bother because at the rear I'm either staying with the same setting or making small changes from my nominal setting. At the front I'm either at zero toe or more usually at slight toe out.
Interestingly when discussing alignment settings with fellow AXers we usually refer to front toe-out in 1/16s of an inch, such as 1/16", 1/8", or 3/16" out, because most of us are setting our front toe at home with toe plates. There are several SCCA national champions and trophy winners in the club I autocross with, certainly not idiots.
Of course for camber I do use degrees, and for rear Kinematic toe I use bubbles LOL.
G
