sedan tow vehicle--advice?
I'm looking at trailers, and would like to get some opinions on my tow vehicle. I'll be using a '95 chevy caprice. Rear wheel drive, solid axle, 4.7 v8, automatic transmission. It has a 5,000lb tow capacity. I'm guessing that my whole rig will be pretty close to that limit. The drivetrain layout, components, and total vehicle weight (4,100lb) are very close to a full size v8 pickup, but the pickup tow capacity is 2,000 lb higher. I plan to add gas shocks in the front, and air shocks in the rear to stiffen up the suspension. And, add a transmission cooler, and maybe an anti sway bar. What causes the difference in tow capacity given the 2 are very similar except for the body? Is it the softer stock suspension of the sedan? Any thoughts?
Thanks!
David
Thanks!
David
Lifetime Rennlist Member
Some, but not all of the differences include:
Frame strength
Hitch rating may or may not be comprable
Axle (rear-end) strength
Spring rates
Tire load carrying capacity
Transmission
Engine (calibration and/or parts)
Cooling capacity
That car and a 1/2 ton pick-up are not fundamentally the same vehicle.
Frame strength
Spring rates
Transmission
Cooling capacity
