Starting gremlin
Starting gremlin
Ok after 24 years of no worries....
All electrical works but not starting...no starter noise nothing. Then wait a bit and it will start.
I suppose it is a relay??
Anyone know this issue and what part is needed?
Starter works perfect just this funny gremlin.
It has for 24 years always started on the first twist.
Build date 2/94--thanks
How old is your battery?
Do you hear a click when it won't start as the solenoid kicks in but does not fully drive the gear home or make the electrical connection to start the starter's motor? If:
If no click or sound, and
- The battery is good (>12.5 volts),
- The ground and hot connections on the battery and the starter have been removed cleaned and reinstalled
- The ground and hot connections have been removed cleaned and reinstalled.
- I would look into testing, with a voltmeter, replacing if needed, the ignition switch.
Hi, in case it's the DME relay, here is a picture of its location (from Pelican website). There are a lot of threads on the topic. This would be easy and not expensive to start with and it's recommanded to have a spare DME relay anyway.
https://www.pelicanparts.com/techart...leshooting.htm
By the way, I have the exact same issue. 30% of the time, I turn the key and nothing but it start without any issue after a 2 or 3 trials. I have a spare DME and will install it today to see. I did not test other things yet but I did replace battery, ground cable, ignition switch and rebuilt the starter in the last 2 years.
It has been so long since I have needed to swap out this relay. Does the relay failure stop the starter from spinning the engine or does it allow the engine to spin from the starter but not kick over and run?
Andy
In my case, I hear a "click" but nothing else. The engine doesn't make any sound or doesn't turn. As an example, it happens that I can't start the car, so I try again every 3 seconds and the 4th time it will work easily as if the car was new. I am no specialist but I wouldn't think it's a battery (energy) issue since the engine will start easily when it works.
I was not in a rush to try the DME relay option since it works fine most of the time and if it doesn't work the first time, it will work a few seconds after. But this thread is making me curious... I'm at work but will go check the relay now to see the solder joints. And I'll try to start the car making a video if I'm having trouble to start. I'll replace the DME relay since the spare is in the car but I will only be comfortable to confirm if it worked in 2-3 days since the problem is intermittent.
"Unfortunately" I tried to start the car and it worked. I'll try to make a video the next times so OP can confirm we talk about the same issue. And I don't want to hijack this thread but just hoping to help OP.
I'll keep update if I find the cause. And OP, please keep us updated too.
- My DME relay was a "993" part. OP, FYI I think the DME relay issue is known on the 993 relay starting with 944 part #. If yours is a 944 part #, I would start replacing it.
- I still looked at the solder joints and don't see any cracks. You can see the pictures below. Although by experience (on my convertible control unit), the cracks can be very subtle. On my control unit I couldn't see any issue but a knowledgeable person immediatly saw few issues.
I had some non-start issues recently, it ended up being a faulty connection between the chip and the DME, you can read the full story and other useful information in these threads: https://rennlist.com/forums/993-foru...talling-3.html and https://rennlist.com/forums/993-foru...g-993-a-2.html
Andy
Thanks! You're right. If removing the relay would be the same as a bad relay, the engine will turn without starting. I just tried.
You're absolutely check. It's interesting how many posts reference the DME relay for a no-crank situation. Maybe because of the incorrect thread title, No-Start.
Just wondering if this could be the OP's problem or does a '94 even have the starter relay?
Curious if you know.
