993 Tranny Oil Suggestion
I apologize if this has been discussed before.
I have a 993 with 12-13k miles and orig tranny fluid. I will be changing the fluid myself soon, went on Suncoast and was met with 3 choices. Would anyone be able to recommend which one to use. As i'll be saving a couple bucks doing it myself I have no problem spending more for a better fluid.
Suncoast has the Porsche labeled "transaxle fluid"
https://www.suncoastparts.com/product/99991754600.html
Mobil 1 PTX
https://www.suncoastparts.com/product/00004320420L.html
Mobile 1 Delvac
https://www.suncoastparts.com/product/DELVAC.html
Mobil 1 PTX
Mobile 1 Delvac
I went with the first one you listed last change. Worked well at all temps.
Delvac is great for a track car but I'd use either PTX or the Porsche fluid for a street car.
The big difference you'll notice is the better cold shifts w/ the latter two options relative to Delvac
Received 5,388 Likes
Originally Posted by Paseb
Whats the quantity needed for a 1995 manual trans?
Originally Posted by LexVan
With no front transfer case, you can get buy with 1 gallon. The 4S and Turbos need over 1 gallon.
So 1 gallon?
Its a c4 and im converting to a c2 in the next few days
So 1 gallon?
So 1 gallon?
I'm probably one of the few that's tried all three of those + the Redline 75w90 NS mentioned above.
I much preferred the #1 and #2 (the Shell-based factory fill and the newer Mobilube PTX) in your list to the Delvac and Redline. As Bill mentioned the cold shifts were much, much improved with either of the Porsche oils.
With only 13K miles on the box most any of the recommended options above should work just fine. It is when you approach the end of the service life of the first and second gear synchros small differences in the viscosity of the gear lubricant make a big difference in drivability. For some that is around 80k miles for others that is well over 100k miles.
Andy
Andy
+2. Exactly what I do. Delvac needs heat for smooth shifting but this is exactly what is needed on the track.
