Lost radio code.
Lost radio code.
Hi to all disconnected my battery and when reconnected radio says i need my code. I have gone on the Renntech site under lost radio code. Now my question is do i have to pull radio out of dash to get my serial # ?. Thank's for any help.
Thank you guys ill try the dealer 1st probably the part's dept.
All of the above is correct, unless you have a 1995 with the CR-1 cassette radio. There is no way to recover the radio code for these radios. It has to be sent to an independent radio shop and they can reset a new code. I went through this with my '95.
Chuck, I think if the CR-1 is original to the car, the Porsche Dealer can obtain the radio, alarm codes, etc.
Another possibility--open your ash tray and flip down the metal spring-loaded flap inside the top--I've see some radio codes there.
There is also a credit-card sized piece of plastic with the code number sometimes found vehicle documents.
My car is a 1998 carrera s and has the cassette in face of radio. I have checked ash tray and book both a no go. Thank's guys.
If your radio is original to your car, your Porsche Dealer will have your codes. Depending on how well your Porsche Dealer knows you, you may need to prove ownership of your car. Bring your registration card and your driver's license.
Hi guys,
I found this website after a long search : http://www.radio-code.lt/
You can retrieve your radio code for free (just need to register with an email address though).
Put your radio serial number and the website will return your radio code.
I checked on a Becker Traffic Pro and the code works so this website is legit (no affiliation). No need to pay to get your radio code back.
