in in the middle of my engine drop. Seems that the engine is snagged on the bolt in the center of the picture on the driver side inner corner. All the research I read didn’t mention about removing this bolt- it seems to be attached to the subframe. Do I remove it or just reposition slightly to get it unsnaggged?
So plan to replace my slipping clutch @58k mi with an RS LFW and clutch. Spotted leaks on the valve and timing chain covers:
my work list:
- RS LFW and clutch kit
- new slave cylinder and hose and bleed
- new engine pad (yes, found a mouse home, and an actual mouse - yuck - he must have had the same air-cooled addiction)
- new gaskets and bolts for valve and chain covers
- all belts
- spark plug wires, new plugs, distributor caps and rotors
- RS engine mounts
- FD SSK
- oil and transmission change
- fuel filter change - so easy now with the engine out
any thing else I should do while the engine is out?
thinking of replacing the oil lever sensor as the needle hasn’t moved as well. Not sure if it’s worthwhile to replace though...
That's pretty much exactly what I did. Few things to add: SAI, fuel filter, and distributor rebuild. Also might as well do any and all sensors and senders.
I just did similar this winter. In addition to yours and ski's items:
varioram flapper valve seal (for which I have a spare, lemme know if you need), and clean up the oil inside the intake - I took mine apart.
Varioram vacuum actuators
O2 sensors
Hydraulic lifters
PS belt
Clean idle air valve, MAF, crud in intake ports
Check the CV boots, good time to fix if needed
Order up new hardware for the entire exhaust system - some will break, all are rusty.
Good time to replace any heat shields that might be rusty, they're still available and not too $$
If you have a good local alternator shop, have it at least tested and if needed rebuilt while it's out. Cost me under $200 for bearings and regulator. Consider fan bearing at this time.
Same with starter. Mine needed a new and unavailable Bendix, but new Bosch starter was $250 on Amazon.
Consider deleting the clutch vent tube
Consider having the injectors cleaned. Mine were down 15% in flow and varied a lot between them.
Two tips:
Be careful with the chain tensioners, they have a proper orientation. Get one wrong and the engine knocks like a bad rod until you reverse the offending tensioner, and you have to redo both to be sure!
To punch the sound pad holes, line it up carefully and use a hot soldering iron to go through the material. You'll sacrifice the iron tip but the result is worth it.
Oil level sensor may just need bending of the float to get it in range when correct oil level reads on dipstick
id go through all the sensors and clean the contacts with pencil eraser and contact cleaner and then seal connectors with dielectric grease. Should be good for another 20 years!
A major project inevitably runs into the unexpected. Builds character and resolve. You deserve a ....especially to those who can do it single-handily and on jack stands.
Hi Ed - the varioram flapper valve - is that the center actuator under the intake manifold? Look likes I have a lot of oil residue and crud there. New seal will fix it? What’s the benefit of the clutch vent tube delete? Easier access to the plugs? Thanks for the tips!
mPit, Henry. Thank u. it actually wasn’t difficult. Normal tools, great advice on this board. I was doing lot a lot research for a while and gradually accumulated the recommended tools. Found my self moving up engine jack, lowering the body, then vice a versa a bit to get the right drop.
Iain - thanks. I’ll take a look to see if the float is bent in anyway. The levle gauge was always on the lowest level ever since I had the car and never moved. The Bentley manual recommends testing the resistance to see if the sensor is defective.
thanks again for the advice. I think installation will be interesting to be able to line everything up for the install.
