Help with centering bucket seats
I picked up some euro gt3 seats a while back and finally got around to install them. As a side note, while my soft back sport seats are really comfortable and supportive, for my body shape these gt3 seats are comparable!
I used Recaro sliders and planted sides instead of modifying the stock 996 sliders and sides.
What I found is that the seat is slightly off center and closer to the driver door jamb. Here are some pics as you can see there is some space on the tunnel compared with my sport seat which is still on the passenger side.
In this current setup my arms are slightly pointing right when I grip the wheel.
My sides are square and don't have much adjustment to move the seat closer to the tunnel.
I looked at the stock 996 sides and noticed the sides are slightly off center which would correct this issue.
Any suggeations to improve?
Is this something you notice while driving or just a visual observation as the offset seems quits small.
It is is enough off center for my right shoulder to feel it.
Removing the seat out and see if I can offset the tunnel side closer to the tunnel...
I've got Recaro Pole Positions with the Recaro sliders and Alum. sides. The right side of the driver's seat is close up against the center tunnel so there's just barely enough room for the stock seatbelt receptacle strap to fit, and the steering wheel is still off to the right.
Just figured this was a Porsche 993 "Feature" along with the pedals being offset to the right. Can't remember where I saw this; " How do you recognize a 993 driver ? Their hips are offset to the right !"
There are spacers between my Pole Position seats and the Recaro sides.
I wonder if you could spacer your seat to the right with different sides? Maybe that would help a little?
I noticed this even with the stock standard 993 seats.
Yes made sure when I drilled extra holes in my Recaro sliders they are centered and with a drlll press. Mounted the Planted sides square to the Recaro sliders and the Recaro sliders square with the mount points on the car tub.
That is a great solution. Did not thick about putting some thick washers on the door jam side and then move the tunnel side closer to the tunnel an equal amount. Thanks!
Most cars I've replaced seats in, at least staring in the 80s and through 2000s, have their seats offset. They play a cute game where the seat is mounted slightly angled "in" so you feel that middle of your chest loos directly at the middle of the steering wheel. But once an aftermarket seat is mounted... the mount manufacturers make mounts straight and square. The seats end up a an inch or two to the left, hands are oddly cocked to the right and ACD becomes a good excuse for being slow on the track.
I play odd games with spacers sometimes, but this is one of the things I hate about installing aftermarket seats.
