Suspension Setup Choice
#62
Car is still with Hergesheimer MotorSports
apparently i messed up on some of the install (missing spacers and wrong tie rod ends) and ride height, corner balance, alignment...
i returned the h&r sway bars, I’ll look for trg or Rs sets...
pss9 set posted on eBay, how much are they worth? I listed it for $800 with the h&r springs
#63
Didn't your car have RS wheel carriers w/ the Rs outer tie rod ends?
Here's the difference
You can also use RSR inners w/ the RS outer, that's what I'd recommend.
The RS still have rubber, the RSR are pure spherical,
The upper here is a stock outer/inner, the lower is RS outer w/ RSR inner
#64
Save your self a lot of trouble and get RS
Bill, i am running the Rs uprights, rsr inners and Tarret tie rods w bump steer
#66
Will they check bump steer on both front and rear or just rear? I've been following this closely because I've just got the same setup (but with JRZ's), had a very reputable race shop set it up for me and after 2 weekends at the track with their support I was still almost a second slower than before I installed the new parts. I took it to my mechanic at Porsche who does all of my other work and we found that it had a lot of bump steer in the rear. I've purchased the longacre bump steer tool and we are working on that next week. Another thing that was a problem is the JRZ suspension I have was for a RSCS and after installed rear wheels seemed to be droop limited (1" down and 5" up). We have gotten some 1.75" spacers made to move the suspension down to have 3" of travel each way.
#70
Assuming that you car is set up like the factory did for Cup & RSR, as shown here. Use the factory specs as shown.
For both front & rear the less castor the more pronounced any bump steer will be, so too speed an end up lower caster to slow it down decrease caster, Every driver will have slightly different tastes in this regard.
here's a bump sweep for a stock RoW height 993, the reddish curve is the bump, Ideally you want a vertical line, lowering actually puts the car into a better part of the curve, the dashed blue line is lowered to RS height, The RS wheel carriers and tie rods further improve the curve
#71
It's more important in front because you have the steering from the driver and steering from wheel travel, In back it's also important but the issue can be narrowed down and solved far more easily.
#72
Thanks Bill. I see that you run 0 toe front and .18 degrees toe in rear and I had my car set to your specs before these modifications. Am I reading this right that RSR/Cup had +0.05 Degrees toe in front and +0.30 degrees toe in rear? Why do you not like those specs for yourself? Some race shops are recommending 1/16" total toe out Front and 1/8" total toe In Rear. Since I using an alignment machine, if I'm not mistaken that's front -0.14 degrees and rear +0.28 degrees. I'm running same tire setup as RSR/Cup but BBS E88 8.5"x18" ET 48.5 and 10"x18" ET63 wheels. What are your thoughts?
Similar situation in back, but I like a little slower rear wrt the front so in back more caster, but retain toe in for braking stability
You front wheels imparts a larger scrub radius than mine, you will have better feel and self centering and better turn in, the only downside is less room at the lip
