Cracked Engine Carrier
Even a tiny edge nick to sheet metal can become a propagation point for a crack that over many miles will grow. I once saw a demo where a guy used a straight pin to scratch the fillet radius under the head of a 3/4" bolt. He then tightened down the bolt in a jig and with almost no effort the head of the bolt, as Dirty Harry would say, popped clean off.
I suspect a little welding of the crack and the fix will be in!
Was that a 3/4-10 coarse thread UNC balsa wood bolt or a 3/4-16 fine thread UNF balsa wood bolt?
Andreas
This one is on my 964, rothsport reinforced it. The factory one, 100% stock car was stressed when removed from the car. My 89 also had similar cracking (g body carrera) on a 100% stock car. We gusseted and reinforced that one while engine was out for service.
Skidmore-Wilhelm Bolt Tension Measuring Devices
No joke here.Andy
Has anybody tried the tubular engine carrier from Rennline? Not that much more expensive than sending a stock one in for the reinforcement installation.
http://www.rennline.com/964_993-Tubu...oductinfo/M19/
