Vacuum Actuators
Vacuum Actuators
So I decided to switch out the actuators. Did four actuators in the engine bay. The one under intake manifold was a bitch to do. Also pulled out the CCU and the fifth one worked, but hinge was broken. Talk about a tight fit. Zip tied the hinge for now until I can come up with a solution or buy a new unit. Anyone have a DIY for the flap AC actuator?
End result - wow!! Car feels like it has more throttle response. Additionally around 5k there is a noticeable change in sound even with Fister III's. It gets even louder now. Definitely an increase in power. Before around 5k rpm the car felt flat and didnt feel like it was making power till redline. Now it pulls all the way to redline and has a kick at 5k. Very happy!! Driven for a year and a few months and didn't know what I was missing. Always thought it felt sluggish though. Just wanted to thank everyone for the prior threads to help me DIY.
The zip tie fix for the missing elbow plug in the resirc flap mechanism works great, I've done this several times. In my opinion, there's no need for trying to source a new plastic plug.
Cheers,
Tore
Cheers,
Tore
Did four actuators in the engine bay. The one under intake manifold was a bitch to do. Also pulled out the CCU and the fifth one worked, but hinge was broken. Talk about a tight fit. Zip tied the hinge for now until I can come up with a solution or buy a new unit. Anyone have a DIY for the flap AC actuator?.
The other new replacement actuators seem to have silicone rubber diaphragms now and should last the life of the car, unlike the old rubber ones.
Great to see you had a satisfying DIY experience.
Andy
I used a stubby screwdriver tip inserted in the end of a small box end ratchet wrench on the mounting screws.
I also attached a little machine wire to the wrench and used some thin sheet metal to make a small wedge to bind the screwdriver bit to the wrench both actions with the goal to not drop the bit or the entire tool behind the engine.
Takes patience but eventually, the old one can be removed and a new one put in its place without disturbing the Varioram manifold.
Andy
Andy
Andy
Andy
I have a 96 Varioram- is this a recommended maintenance item? Could you point me in the direction of a DIY guide anywhere please? Thank you.
I have a 96 Varioram- is this a recommended maintenance item? If you are looking for it in some sort of Porsche Technical Service Bulletin, no. However vacuum leaks should be resolved and on our 20-year-old cars most likely one or more of the actuators is leaking, interestingly the leak can effect performance but does not generally throw an OBDC code.
Could you point me in the direction of a DIY guide anywhere, please?
The below URLs point to a testing procedure and discusses replacing the actuators.
Andy
Thank you Andy
