RS door cards in 993?
I have installed a set. i didn't like the material of the appbiz cards as they are a cardboard/fiberboard that deforms over time. i opted to used my appbiz kit as a template and make them out of ABS sheets. and re wrap them with suede.
the issue if you don't buy the kit is getting all the hardware like the door pulls. BTW the 964 and 993 use the same template for door cards. i believe also the appbiz kit is the same as the rennline
Hi,
Wondering if anyone has installed the Rennline RS doorcards on a 993? (RSD-NF-911-06-00)
it lists compatability w/ 65-94. On some of the other doorcards (appbiz etc) they list up to 98, so wondering what the difference is. The rennsport variant list @ $250, half that of Appbiz, so hoping to make them work.
cheers!
cheers!
Rennline RS Door Card
I made my own..
Here's the What did you do to your 993.. Thread of when I put mine together if you fancy a look..
https://rennlist.com/forums/993-foru...l#post16292810
