Power seat stuck
After the detail shop moved my seat all the way back, it stopped moving. But unlike most threads here about "stuck seat", the switches don't cause any motors to click/thunk/run. Pushing forward, up, or down, or tilting the seat, elicits no motor attempt.
I'm guessing some cable/connection came loose under the seat. Anyone have any suggestions where to start? There is *quite* the rats nest of wires and relays under the driver's seat.
If u can not see or feel a blockage?
were they removed?
All bolts in place? So seat situated properly?
Push switch to bring seat down so base is flat
No power?
Pull apart power switch Gently.
Located Under Seat
Spray switch with electronic contact / connection cleaner
Couple other bits there..need a schematic to answer
But there is a long skinny cable that can become loose or break.
If broken cable seat will pull to one side.
Check if the cable ends are tight. Or open to inspect.
its near front. Beneath knees..say 8 inches long
Hope this helps
TJ
Ps...make seat base flat
were they removed?
No power?
Located Under Seat
Hope this helps
TJ
I was cleaning my car once and operating both seat switches at the same time blew the fuse. I know you've already checked it but maybe have another look as it seems like a very likely explanation.
