Please help: Gear shift knob won't go down
Please help: Gear shift **** won't go down
Does anyone have any tips on how to get the gear shift **** to seat all the way down? Mine sits really high. I've leaned and pushed on it all I can, but it won't go down any further. Is a rubber mallet in order? Other tricks?
Spray some silicone lubricant in the **** hole and slide it on. It will be tight but will eventually set. I wouldn't use a hammer as you are putting stress on the shifter linkage.
It's been a while since I've had mine off, but I seem to remember there are 2 different type *****. One will not seat as low as the other. I replaced my leather with the carbon fiber, and it does not seat as low as the leather.
In all seriousness, if lubricant isn't the answer, try using a (rat tail) edit, tapered square file (since the hole is actually rectangular in shape) of the appropriate size to slightly bevel/taper the leading edge and then reapply the KY.
