993 Forum 1995-1998
instrument trim rings
Old Dec 19, 2003 | 06:12 PM
FlyYellow's Avatar
FlyYellow
Default instrument trim rings
Can anyone tell me how to install the aluminum instrument trim rings?
I'm thinking of using a 3M adhesive spray on their inside of the ring. Or is there a good way of doing it?
Cheers,
Boris
Old Dec 19, 2003 | 06:22 PM
Phil's Avatar
Phil
Phlat Black Guru
Lifetime Member
- Times 2
Boris,
I used rubber cement glue.
Old Dec 19, 2003 | 07:02 PM
hughfi's Avatar
hughfi
I used black rubberised glue also. It works a charm and insures that they fit very well.
H.
Old Dec 19, 2003 | 08:08 PM
JMc's Avatar
JMc
Four little dots of a silicon adhesive like Permatex will hold like a champ and allow removal and easy cleanup if ever desired.
Old Dec 21, 2003 | 02:16 AM
FlatSix911's Avatar
FlatSix911
Boris, I went to the local office supply store and picked up some poster mounting tape -- it is double sided and can be easily removed without leaving any residue.
Old Dec 21, 2003 | 02:22 AM
ksjcorpus's Avatar
ksjcorpus
boris i used poster putty .. i wadded it up in a tiny little ball and placed 4 on each ring and presto done. it's snug but the rings can be taken off easily without damaging anything.
Old Dec 21, 2003 | 10:14 AM
milrad's Avatar
milrad
PS Armorer
Poster putty, purchased at Lowe's. Worked like a charm!
Old Dec 21, 2003 | 11:09 PM
Jim's Avatar
Jim
I used "Museum Wax" which is easily removable and very sticky. Kind of like soft parrafin. I got it in an Art store, and it is designed to keep your statues stuck down during earthquake tremors, ahh California...
Jim
Old Dec 22, 2003 | 11:29 AM
SMB993TT's Avatar
SMB993TT
Ditto on the poster putty. Mine have been on for about a year and a half with no problems.
Old Dec 23, 2003 | 01:44 PM
OldGuy's Avatar
OldGuy
How do you get the black ones off??
Old Dec 23, 2003 | 01:54 PM
GrantG's Avatar
GrantG
OG - I think the new ones fit over the black ones (no need to remove them).
Phil's Avatar
Phil
Phlat Black Guru
Lifetime Member
- Times 2
the rings go over the black plastic rings
Old Dec 23, 2003 | 01:59 PM
OldGuy's Avatar
OldGuy
Cool, thanks guys, that was on my upgrade list.
But right now gotta pay for some muffler bypasses
and some ROW springs and euro torsion bar
Old Dec 23, 2003 | 02:00 PM
JMc's Avatar
JMc
All the trim rings go on over the top edges of the gauges...
...oops, sorry, never mind.
Old Dec 23, 2003 | 03:23 PM
ca993twin's Avatar
ca993twin
Old guy,
When you come down to visit, you can see my trim rings. I used double sided tape because I am a mechanical doofus, and knew I'd make a mess with anything else. 10 minute install, even for me. And its a "Euro turbo rear sway bar", not a "torsion bar"... you're gonna really confuse a few folks. And I've been told that I'm already very confused.
