instrument trim rings
OFE I made a mistake-we had a lot of
TENSION in the office this morning while I was
typing. SOmeone was trying to SWAY me into
their perspective. So when I typed it came
out Torsion. My bad. And No I dont read Rennlist
at work!
at work!
No, those are formed (bent) which kinda suck... better to get the machined ones, from:
http://www.stores.ebay.de/tachoperformancecupsport
They also have lots of drooley billet stuff..
Coleman.
Coleman.
i used poster puddy as someone suggested. so far worked great. oh and i got the cheap set that was referenced on ebay. i'm actually happier with that set as i didn't want to cover up the entire bezel. i thought it'd looked better to have a bit more contrast.
cheers,
boris
cheers,
boris
Cetro,
The trim rings just install over the existing bezels. Nothing is removed. The install is completly harmless (depending upon the adhesive you use). I used double sided tape, and it took all of ten minutes to install the complete set, and I'm a doofus. Happy Holidays.
ca993twin,
When I try to install the bezel, it get's caught against the steering column. I can't get the bezel to go down far enough. Do the 993 have adjustable steering?
I would recommend not using anything but the putty or tape-these can both be easily removed if need be. I have the machined ones and they are great. I chose the brushed finish-matches my aluminum shifter, hand brake and B-K harness bar. All against a black interior. Just thinking about it makes me want to have a cigarette....
