Re-oil BMC air filter ?
Is there any trick to that ? I would think that too much (can mess up the air mass flow meter ?) or too little (allows more dust to come in) is no good. What's the happy medium and how do i tell ? Thanks !!
With all honesty in mind, pack it up and put the stock filter back in. There are no measured improvements other than the psychological feel.
Barring that, look for complete coverage of the pores. Let it sit on a piece of newspaper for a day or two to drain any excess out before installing it.
RL Technical Advisor
[quote]Originally posted by last993:
<strong>Is there any trick to that ? I would think that too much (can mess up the air mass flow meter ?) or too little (allows more dust to come in) is no good. What's the happy medium and how do i tell ? Thanks !! </strong><hr></blockquote>
Hi:
After you have cleaned the filter and its thoroughly dry, spray a nice even coat of oil so that you see a uniform color all over the cotton gauze. Let it dry face down on some newspapers, just as Mark suggested for 12 hours or so. As long as the oil is allowed to dry properly, you will not contaminate the MAFS.
I also always apply a layer of grease to the rubber perimeter seal to ensure that no air can leak around the element. Been doing that with K&N's for 30+ years,... Never a problem.
Enjoy,
Hi:
Enjoy,
[quote]I also always apply a layer of grease to the rubber perimeter seal to ensure that no air can leak around the element.<hr></blockquote>
With all due respect to Steve, I would just ditch the K&N. K&N isn't even selling these for 993s anymore because the seal could crumble and get sucked into the engine.
When I got my 993 from the PO, it had a K&N. I looked at the seal and it was in tatters in places from the airbox edges.
Oops, just realized you said a BMC filter, not K&N. I hope the seals on those are more reliable than the K&N I used to have.
Brett
Brett
[quote]Originally posted by Brett-1996 C4:
<strong>
Brett</strong><hr></blockquote>
Brett:
You are right on, the K&N 993 Filter is to be avoided. These have had problems and they do not fit the airbox very well at all.
I would use either the BMC one or the Factory paper element.
<strong>
Brett:
The BMC does not fit terribly well either and, every one I have seen is dripping with oil. As an alternative, might I suggest the Knecht that the factory has used in certain applications and that is similar in flow characteristics to the K&N or the BMC -- and its fits and is not oily. Of course, as noted above, in the real world, the improvement produced by any of these high line filters is primarily in the mind and not on the dyno (of course, if I compare a new K&N to another filter with hundreds of thousands of miles of dirt therein, the results will be noticeable, but that is hardly apples to apples).
I had a BMC filter for a year and a half, the the seal separated. Fabspeed replaced it with a new one. I haven't tried it this, but it was recomended that I trim the edges of the new one to avoid this, and that it was caused by the too- tight fitting airbox. Has anyone tried this?
David
David
K & N Revised with new rubber seal, I installed
a new one last week.
Carlos
<a href="http://www.p-car.com/porsche/carlos" target="_blank">www.p-car.com/porsche/carlos</a>
Carlos
