Spark Plug Wires
Spark Plug Wires
While changes plugs I noticed a couple wires were cracked. Did the caps/rotors and now thinking I will install new wires. Found DIY and my hand will not fit between intake runners. Guy must have small hands in the diy. I will not be denied! Can I remove the Allen bolts on the intake manifold to get room? Is there a gasket? I anm getting a 90 degree screw driver to help, but space is limited. Any helpful hints? Thanks in advance!
Also there is two Beru kits on pelican. What is the difference?
Removing intake is actually not that bad. Plus if you have V-ram you can replace the leaking gasket. The trickiest part is disconnecting throttle cable (blind) and for some reason reinstalling the ISV. You will have to lower the motor slightly (i.e. disconnect engine mounts) to get intake out.
Thank you for the responses. Still not crazy about taking the how intake manifold out. I was just planning on loosening the intake manifold runner bolts. About to order now the wires.
I would just lift the intake manifold rather than removing it, I've done both and lifting it alone will give you a lot more room to work as long as you unbolt the motor mounts and lower the engine down some. Be careful to plug the intakes so nothing falls into the engine.
Removing it altogether does make plug wires a cake walk though.
https://rennlist.com/forums/993-foru...lug-wires.html
Basic Sponsor
What is the year of your 993? Sometimes if we have 2 of the same parts listed, it's because they're from 2 different suppliers of ours. Sometimes one supplier has a lower price than the other- doesn't mean the parts are different.
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Pelican - thank you for the reply. I submitted my order and you sent me a tracking already. Looking forward to the bruises and bleeding...lol
OK - so I have just spent like 30 minutes looking at this. What a nightmare getting to those two sets of screws on the inside. My hand is unfortunately big so no go on the Runner 5 and 6 access. Even then I don't know about the other screws on the other side.
Venting - the person who designed this car really wanted to torture us. Why not push the screws towards the outside. That and the secondary slave clutch.
So how do I remove intake manifold. What am I missing below
1. Intake runner clamps (bottom or top)?
2, Two bolts holding it the brace on left hand side
3, Remove ISV
4. Lower engine - do you have to do four bolts? I know where the normal bolts are for engine mounts toward bumper. Jack under and slowly lower - how much?
5. I see one or two hose clamps way in the back
3, Remove ISV
Success...took of icv and loosened intake runners....pulled up and got my hands under there....so happy! Bought a stubby screwdriver. Running the new wires now. Victory!!!
