Softronic 992
Excellent thread, Scott, thanks for sharing the intel.
I am moving my questions from email to this forum, as others might find this relevant as well.
I have 992 T MY2023, 7-MT.
Is there an option for 450HP, with more torque at lower RPM? Not higher RPM.
My 992 T has 385PS @6’500 and 450Nm @1’950
IIRC 992 S had 450PS @6’500 and 530Nm @2’300
IIRC 992 GTS had 480PS @6’500 and 570Nm @2’300
I don’t want to trade PS for Nm at higher RPM. I would be more excited about higher Torque at lower RPM, e.g. 530Nm but at 1’950, not 2’300 RPM
thanks again for all the detailed info.
Why dont you call me as I'm not sure what you specifically want as yes the turbos are smaller so they are limited to where they can build the TQ compared to the S or GTS yet naturally would come in sooner to start with.
It sounds like you are looking for something a tuned file is already doing from the beginning as it's increased through the entire range.
Semper Fi!
Scott
Semper Fi!
Scott
I spoke with Scott and I was very impressed. Unpretentious professional, running solid business.
Scott, thanks for taking the time to share your knowledge and experience.
I will have to upgrade my 992 with the Softonic mapping and experience what this car is capable of . . . I just need to nurse my injury first, so that I can drive again.
I will also have to look into brakes upgrade to preserve the golden ratio of acceleration to stopping power. But that is a separate/parallel discussion.
He is a class act for sure. Looking forward to following your modification journey.
Having not read 13 pages of posts completely, I'm not sure if this is covered, but I see that on the Softronic site he specifically mentions NOT eliminating cold start, while I know that is a feature available and often selected with those who opt for M-engineering's Coder/Tuner.
Scott's site says he can, but recommends against.
Curious why?
Curious why?
Curious why?
Curious why?
Curious why?
Curious why?
Cold start serves multiple functions, including preheating the cats, ensuring adequate oil pressure, and initiating the heating cycle of the engine oil. For me, that last point is perhaps the most important. Engine oil serves a very critical role beyond simple lubricity, and brining it up to operating temperature before placing the engine under a load, is one of the best things an operator can do for the longevity of their car. There are other considerations regarding the lubricity of fuel, challenges with horizontal cylinders, and direct injectors, but discussion's around that subject tend to devolve into bickering.
Does cold start suggest one does not move the vehicle until after the completion of the 90 second cold start routine. It's not physically possible to drive it without breaking the cold start rpm and as a result placing the engine under a load greater than the cold start routine.
Curious why?
Curious why?
My understanding is that temp needs to be above 180 before putting the car above 4000 rpms as a general guideline and that even with a cold start, the car won't approach that temperature for at least a few miles. One would be sitting there for 5-10 minutes waiting on adequate temp and that cold start high throttle drops long before ideal temp is reached.
Yep, me too.
