They need to reset your computer so it doesn't show any errors, then take the car drive it till the code appears again and take it to them. I just picked my car today for the same issue , injector replaced
They always tell me they reset it and cant see anything. It stopped between year 2 and 4 after I gave up and tried 2 tanks of Techron on a whim (fuel injector cleaner). In the past 6 months it resurfaced here and there but its not consistent. This is when I started hooking up my code reader and recording the pending codes before I turn the car off. Whenever I try to reproduce it to drive straight to the dealer it never happens lol.
Ill try them again now that I have some proof and hopefully they have seen it on other cars now that the platform is 4+ years
Ugghh...my 2021 S 7MT has started to do this at 21k miles in the past few weeks with increasing frequency. Tried a tank with a bottle of Techron with no improvement. Last Friday, happened about 5 times in a 20 minute drive. I can typically induce it by doing a light pull in 2nd or 3rd and abruptly letting off the gas. I hooked up my Veepak bluetooth dongle and used the CarScanner android app to try to read a code, but since there was technically no MIL, nothing showed up.
So I got up Saturday with the intention of having the error and driving to the dealer without turning the car off -- drove around for 3 hours with no error. Of course.
Go on the highway put it on 5th or 6th let it slow down to 50mph ? or 60? where you would obviously go to 3rd or 2nd but leave it at 6th and then floor it , guaranteed it will shudder and message will appear
Weird, same year, model and mileage and same thing just started happening.
I made a post about this. Look at my history but it was fuel injectors on my 2020 c2s. Happened with full throttle or in sport response mode. Repaired under emissions warranty for free. I was able to induce the error at command (sport response on in sport mode full throttle), and then when the warning triggered I immediately drove to dealer (dont turn car off otherwise error goes away). Good luck.
Brought mine into the dealer today (Porsche Westwood) -- warning came on during the drive in and they pulled codes as soon as I pulled up. No faulty injector codes -- I think my SA had actually read this thread He said they've never replaced an injector on a 992 before that he could remember.
Tech thought it was odd that the reduced engine power warning displays without the MIL.
Instead it showed code P2B3100 which indicates the radiator fan in front of the right front tire was not operating. Tech confirmed that to be the case so I suspect they are going to replace that and give the car back to me and I'll hope that was the issue.
Reason: not BMW duh
