Standard tire pressure
#61
Thank you SO much!! Totally different road feel felt immediately. The car is in Naples FL, the outside temp when I adjusted them was 77, and I adjusted the pressures with a very accurate gauge that I've used and tested against other gauges it it seems to be very accurate.
How is tire wear at 30 - 33 ? I know historically the rears wear faster...But I'm wondering how lower pressures affect wear.
Thanks again!
Thanks again!
Risley (07-29-2024)
#63
29/32 with SPASM stiffer suspension mode was great. With 33/37 I run 50/50 normal or stiff mode depending on the road.
#64
To avoid the warnings, you need to “record” your reference tire pressures in the TPMS with the following procesure:
I find it to be a bit of an over complicated procedure compared to other cars I’ve own/owned, but that’s how it needs to be done (it is in the owner’s manual).
- Adjust your cold tire pressures using an accurate pressure gauge.
- In the TPMS screen on the PCM, select winter tires then select summer tires again (or vice vera if you’re on winter tires)
- Then select whatever combination of option is closest to whatever you inflated your tires to between comfort/normal and normal/full load.
- You well get a message stating the TPMS has been reset and that it needs ~25km to record the pressures (no pressure will be displayed for a few miles of driving, usually less than the stated 25km).
#65
I am glad that we have this thread, especially given that my new C2S arrived late this week and I needed a refresher since my 992 T was pre-traded in May when I acquired my C2S allocation. I ran the comfort pressures on the T at 29f/32r and it substantially made a difference in metro ride quality.
Jeff Whitten (08-25-2024)
