None of those are active codes. Clear all first and then check for active codes. That looks like typical communication error codes when playing with PIWIS. Those will clear.
Sorry I should have been more clear - started my car and it was running crazy rough and these are what were stored.
It's weird to see EVAP system as well as engine faults. Seems like a wiring or general electronics issue unless that EVAP code is old.
Both exhaust cams and both intake cams failed at the same time. Super weird, unless that's just how 911s throw codes if just one of the cam phasers fails.
