A couple frivolous questions...
I have two, perhaps frivolous questions for you seasoned 911 owners.
AC Setting
I’m a “set it to auto and forget it” climate control guy from the BMW crowed. With the 911, auto climate also activates the AC. I understand the AC conditions the air and helps prevent fogging but I would never anticipate needing AC 100% of the time. What do you do during the autumn/winter season when you want your windows down and heat set to auto? Do you set it to auto and then go in and turn the AC off or do you set it to auto and just let the AC run even if the windows are down? I currently do the former and it’s an annoying extra step. In a traditional Chinese family, I was taught to never let precious AC leak to the outside as that was considered wasteful.
Cooling System
I daily drive in Sport Plus Individual exclusively and noticed the cooling system keeps the engine about 10-15% cooler than in Sport/Normal modes. Will I be going through the cooling system components faster than if I drove in Normal or Sport? I suppose one can say I’m stressing the engine less from heat and putting the strain on the cooling system as a benefit but I can also see the difference as negligible.
AC Setting
Cooling System
AC Setting
Cooling System
AC Setting
Cooling System
2) No impact
If you're a 'set it and forget it' person, then you're waaaaaay overthinking this. LOL.
Literally, set it and forget it and go drive it!
woobiee (06-11-2024)
Whether its cold or hot air, I always use AC. I too set it and forget it.
alaris (06-12-2024)
Set it and forget it. Auto temp. Dial in the temp desired. In summer with my cabriolet, top down I’m blasting at 68 to keep things cool. Winter if it’s not raining and above 60F, tops down. 911 designed and tested in wide variety of temps, hot and cold. Likely no difference in wear.
alaris (06-12-2024)
Hahah okok. I must be the crazy one. Gotta unlearn the decades of "don't open the windows and leak AC outside" rule.
Jeff Whitten (06-14-2024)
The following 3 users liked this post by B194HR:
