What are the unexpected things you should know about your 992?
#91
BobcatRidge (06-12-2024)
#92
You can switch off all exterior lights by pressing and holding the parking lights button for a few seconds.
(They automatically come back on after driving 330 miles or exceeding 6 mph).
Just J (06-10-2024)
#93
Clicking both paddle shifters together once engages neutral. And if you quickly remove your foot off the brake pedal and depress it again it activates brake hold. You can then press the up shifter once and it will go into 1st but still keep brake hold active. That's how I discovered it.
#94
#95
Received 2,842 Likes
By design, to stop someone getting squashed between the wheel and the seat.
#96
I would just put the handle in "normally" until the pump shut off and then hold it at 9 until it shut off again. Wasn't horrible but was puzzling until I found the thread on it here.
Going for my first fill up in the Targa today, som I'll see if it's the same.
#97
#98
You can add a 'turn PCM off' button to the home screen which with one touch blacks out the PCM without turning it off. Great for night time runs when all you want is the instruments, but with music still playing.
#99
H-m-m-m-m-m, OK I'm curious . . . . and you know this, how? Please reply quickly before your statement motivates me to go out and put a thermocouple on/in the system. If you're correct, that's not good at all. To be perfectly honest I've never really paid much attention to the digital coolant temperature gauge reading, I don't even have it selected as one of the four in the pod to the right of the tachometer. I ignored it there because the guess-o-meter analog gauge on the far right side of the instrument cluster (hidden by the steering wheel) seemed like it'd be sufficient.
My solution is to have the oil temperature displayed as well; that does show the actual temp at all times and you can clearly see it moving up and down.
#100
Pay attention to your gage and you will notice the same thing.
993RUF (06-12-2024)
#102
#103
#105
F8T and 911T (06-11-2024)
