What are the unexpected things you should know about your 992?
The following 2 users liked this post by SamD:
Jeff Whitten (06-07-2024),
rosco964 (08-13-2024)
I can imagine its a safety feature...in case the memory position is all up to front and you are in the car and get crammed between seat and stearing wheel. When door is open they may assume you are not sitting in there yet and move w/o holdup all the way.
aggie57 (06-10-2024)
On PDK models, Double tapping the right paddle in highest gear allows car to coast as if putting engine in neutral. This works in normal mode. Not sure if works in Sport or Sport plus.
Bluehighways (06-08-2024)
which cupholder do you mean by "passenger cupholder"? The one that comes out of the dash or the one in the door?
I can see if they did this for safety reasons. Imagine driver position A is for a 4 ft 10 person and driver position B is for a 6 ft 5 person. If you accidentally press the button and it starts moving mid-drive, it could put them in a dangerous situation
null (06-07-2024)
Some cars won't fill the full tank all the way if the gas pump handle isn't oriented at 9 o'clock. My .22 C4S cab would stop at 3/4 full unless I did that.
There's a thread somewhere here on this.
The following 2 users liked this post by Keadog:
GuardsRed992 (06-07-2024),
piblondin (06-07-2024)
nyca (06-07-2024)
to realase the seat back pull strap, first press the heel of your palm on the seat back and push towards the back, then pull the strap. this can be done with one hand and works perfect every time.
The following 4 users liked this post by dudeoverthere:
- Holding down the volume **** for a few seconds will turn off the PCM display.
- Pressing and holding the fob lock and unlock button simultaneously for a few seconds until the red fob light turns on and off will disable comfort access and conserve battery life. It will also allow you to wash the car without the trunk constantly opening.
The following 9 users liked this post by jlegelis:
aggie57 (06-10-2024),
Honza (06-07-2024),
piblondin (06-07-2024),
and 4 others liked this post.
The following 3 users liked this post by Michael T:
The following 3 users liked this post by kawter:
Don't read the thread "What did you buy your 992 today" ....you'll be spending money forever! ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
https://rennlist.com/forums/992/1162...ay-thread.html
The following 7 users liked this post by tomtomtomtom:
Bluehighways (06-08-2024),
detansinn (06-07-2024),
Fullyield (06-08-2024),
Newbie T (06-08-2024),
and 2 others liked this post.
