What are the unexpected things you should know about your 992?
Jeff Whitten (06-12-2024)
#107
#108
Brinkmann (06-11-2024)
#110
https://rennlist.com/forums/992/1412...g-the-car.html
Even if you keep holding the key in the start position, the computer stops cranking the engine once it starts, unlike traditional key-start vehicles, where you could over crank the engine if you didn't let go of the key.
#111
txpackers (06-12-2024)
#114
To quickly start the car in Sport mode, do these steps in swift succession:
- Turn the start fob
- Rotate the steering wheel mode dial to Sport mode
- Press the brake pedal
#115
Apparently the digital coolant temp is seen by Porsche more as an idiot light than an actual readout; as in if it's saying 194f (or 90c) then 'all is well in the world'. The simple proof is that 194/90 is displayed regardless of the drive mode selected, even though the engine runs cooler in sport and sport+ than in normal. But if they allow it to a show the actual temp then they'll get more service calls from worried owners. Perhaps they think GT car owners are more informed?
My solution is to have the oil temperature displayed as well; that does show the actual temp at all times and you can clearly see it moving up and down.
#116
IMHO, Oil Temperature is a better indication of engine operating temperature than the Coolant Temperature. Ex: I don't consider the engine (any ICE engine) to be fully warmed up until the Oil Temperature exceeds the Coolant Temperature (5*F-10*F) and over the boiling point of water (super-heat), at the altitude the vehicle is at. Then, Oil Temperatures over 275*F will motivate me to change the oil ASAP as the various additive packages that allow oil to work as we hope it will, start breaking down at around this temperature.
aggie57 (06-13-2024)
#117
#118
I believe the coolant temp gauge does reflect the actual temp it’s just that under normal street driving conditions there is more than enough capacity to maintain 194 F. However, under more demanding conditions such as driving on track with an ambient temp of 80F the system can no longer maintain 194 F, and you will see a higher temp.
#119
