S vs GTS Wheel Offset the Same?
I'm about to order a set of wheels for my 992 GTS. I found an offset / size I really like on a C2S. They're 20x9 ET42 and 21x12 ET60. I assume these specs would look the same on a GTS as it does on an S? Could anyone confirm? Would hate to be wrong with a custom order.
Yes they're both 5 lug. Thanks for the help.
Stock GTS Sizes & Offsets
20x8.5et50
Your new front wheel will be 1.6mm further away from the strut, and poke 14.4mm more on the fender side.
20x11.5et67
Your new rear wheel will be 0.7mm further away from the strut, and poke out 13.4mm more than before on the fender side.
I think you’ll be fine in the front, and it’ll be close in the back, but I think it will work.
20x8.5et50
20x11.5et67
20x8.5et50
20x11.5et67
20x8.5et50
20x11.5et67
That’s how they sit on the C2S. Yes it’s also lowered.
pal (05-07-2024)
The following 2 users liked this post by Brad Stinson:
Master Deep (05-07-2024),
pal (05-07-2024)
Correct. Stock tire size. I really want the HRE 101 but I'm struggling with the thought of 12k for a set of wheels. The only other forged manufacture with the finish I like is BC Forged KL01. Which are $4300. Pretty huge price difference. I could get a set of BC forged and some KW HAS installed and still be around 4k less than just the HREs.
