Tire: patch or replace?
Old Apr 21, 2024 | 04:11 PM
nyone's Avatar
nyone
Default Tire: patch or replace?
Would you patch this hole on brand new tire, or replace it?
Popular Reply
Apr 21, 2024, 04:15 PM
Mondo1's Avatar
Mondo1
That can be patched on the inside. I have patched several tires on my 911 and Cayman and never had an issue.
Old Apr 21, 2024 | 04:13 PM
justme94568's Avatar
justme94568
Replace
Old Apr 21, 2024 | 04:15 PM
Mondo1's Avatar
Mondo1
Old Apr 21, 2024 | 04:20 PM
Orca911's Avatar
Orca911
I'd patch that.
Old Apr 21, 2024 | 04:25 PM
BondJ's Avatar
BondJ
First off, the screw may not have penetrated all the way through. If it has, it looks to be well away from the sidewall. Patch 👍
Old Apr 21, 2024 | 04:30 PM
justme94568
If the nail ruptured the steel belt then the tire integrity is compromised. Why risk the chances of an accident? Replace 100%. If it was a civic and city commute then patch.
Old Apr 21, 2024 | 04:31 PM
Jeff Whitten's Avatar
Jeff Whitten
Inside patch.
Old Apr 21, 2024 | 04:59 PM
TimD's Avatar
TimD
100% Patch
Old Apr 21, 2024 | 05:08 PM
PG5768's Avatar
PG5768
I'd go for a patch.
Old Apr 21, 2024 | 05:09 PM
Scott P's Avatar
Scott P
Sorry but I disagree, it can be easily patched IF you remove the tire from the wheel to do the repair. If you're going to run the car at an HPDE you assert the tires are not patched on the tech form (usually), this is not something I would do (patch/run at HPDE).
Old Apr 21, 2024 | 05:17 PM
swisman's Avatar
swisman
From the picture...tire doesn't look
deflated.
Unless tracking the car. Patching from the inside....should be fine.
Old Apr 21, 2024 | 05:32 PM
shrimp money's Avatar
shrimp money
I'd plug it from the inside.
Old Apr 22, 2024 | 08:46 AM
HudsonOH992GTS's Avatar
HudsonOH992GTS
Patch, but who will do it? Most tire places won’t touch custom wheels (AMG, center locks etc). If it was on the shoulder, no shop will touch it.
Old Apr 22, 2024 | 09:10 AM
HOTCHKIS's Avatar
HOTCHKIS
Costco will plug to fill the void and patch on the inside.
Old Apr 22, 2024 | 12:01 PM
AlterZgo's Avatar
AlterZgo
Definitely plug/patch. I've done this on many tires and they've all held up without issue. It is completely safe even for high speed, aggressive driving. Every Discount Tire will plug/patch that for free including properly rebalancing the rim/tire.
