Navigation Cursor Not Centered in Instrument Cluster
#46
I'm pretty sure Porsche does not do OTA (over the air) updates, except for navigation data.
I believe they perform service bulletin updates when the car is in for service. (Someone correct me if I’m wrong).
Most likely you will have to take it in.
#47
If I’m not mistaken, my MY 2022 PCM6 was updated OTA from the black and white icon version to the version with colored icons.
PSPorsche (06-05-2024)
#50
Just a thought, and apologies if already mentioned. My 24 GTS is off center to left with no active navigation. When route guidance is active, it is off center to the right, and this allows the screen to display sign guidance in the left half of the screen (e.g., exit sign approach, take far right lane image).
Ideally it would be centered, but I can see why its off center left for general view (so you can actually see), and off center right with route guidance as the signs/turn info are more information than a zoomed out map.
#52
Same issue here. Build date 5/24 - C2S.
Come on Porsche! We know you are behind in software development but this is pretty stupid regardless.
zanary (07-20-2024)
#54
https://rennlist.com/forums/992/1230...l#post19555306
Your OTA, was that the same one I posted? I'm curious if yours is a newer one than the ones that came in on Wednesday and do you have screen shots showing what the OTA was for specifically (see my post above).
#55
I think that OTA was the same one that came in on Wednesday. It was three updates actually. I posted details here.
