View Poll Results: Last Option - You can only choose one
LED Matrix Headlights with PDLS+
![](https://rennlist.com/forums/images/polls/bar2-l.gif)
![](https://rennlist.com/forums/images/polls/bar2.gif)
![](https://rennlist.com/forums/images/polls/bar2-r.gif)
![](https://rennlist.com/forums/clear.gif)
13
15.12%
Night Vision Assist
![](https://rennlist.com/forums/images/polls/bar3-l.gif)
![](https://rennlist.com/forums/images/polls/bar3.gif)
![](https://rennlist.com/forums/images/polls/bar3-r.gif)
0
0%
Porsche Dynamic Chassis Control - PDCC
![](https://rennlist.com/forums/images/polls/bar4-l.gif)
![](https://rennlist.com/forums/images/polls/bar4.gif)
![](https://rennlist.com/forums/images/polls/bar4-r.gif)
18
20.93%
None: Save the Money
![](https://rennlist.com/forums/images/polls/bar5-l.gif)
![](https://rennlist.com/forums/images/polls/bar5.gif)
![](https://rennlist.com/forums/images/polls/bar5-r.gif)
55
63.95%
Voters: 86. You may not vote on this poll
New Build Only Have $$$ for One Last Option...
I have a New Build Locking soon and only have $$$ for one of the following Options. Which one would you choose?
Current Configuration: https://configurator.porsche.com/porsche-code/PRNJQAL4
(See Poll Above)
(See Poll Above)
Save your money on the matrix, as I do not think they are yet activated in the US.
If you get PDCC you will also have to add RAS..
I would also opt for PASM sport (lowered -10MM) - for the S you will have less wheel arch showing (and you are not low enough to remove any comfort or need for FAL) - my 992 S coupe before my targa was super compliant even on rough roads with the sports PASM.
Also - You might want to consider the extended rage fuel tank since going with Just the S and not 4S (not available with the 4s).
(See Poll Above)
(See Poll Above)
PDLS+ Is included in the Premium Package, and it swivels the headlights when you turn and automatically adjusts high beams. This should be all you need. Also, the Matrix Headlights are disabled in the U.S. anyway, so if you are U.S. based, you are literally paying for nothing!
Night Vision Assist
People on this forum say Night Vision Assist is useless, but some like it. If you regularly drive at night in an area with deer, it might be useful.
People say PDCC induces a a queasy feeling, especially in passengers, because the way the car stays flat during turns is unnatural. Instead, I would try to spend a coupe of grand extra and get the Sport Package. You’ll get an upgraded lowered suspension and the Sport Chrono Package.
(Humble) Suggestion
I suggest you see how you can add the Sport Package within your budget.
If you can’t do that, add the PASM Sport suspension for $1020 and/or the Sport Chrono Package for $2790. Both of these together are only $3810, which is only $640 more than PDCC alone.
Make up the $640 by sacrificing some of the Exterior options you have selected. For example, the Rear Lid Grille Vertical Slat Inlays in Exterior Color for $720 will hardly be noticeable. Some people just apply special tape to these later. So can you do this, if you decide later you really wanted them.
I know you are going for a gloss black and silver theme, but the $409 Silver Windows Trims may not match as well with your wheels as you think. Also, this might clash with the gloss black $660 Mirror Lower Trim.
You build is nice, and these are just suggestion for saving the $640.
But if you can get the Sports Package, which includes Sports Chrono and Sport PASM, that would be the best way to go.
Night Vision Assist
(Humble) Suggestion
i have night vision assist because i live outside of town where there are lots of deer and elk. other than the one time i tested it in town, it's not picked anything up. i've had it on and come upon deer, elk, foxes, and neighbors walking there dogs with no notification. if it warns me once it will be worth it but i don't expect it to warn me at this point.
matrix lights as mentioned are not functional in the USA
get sport package included with manual transmission.
PDCC requires RAS. I have both and really like them. would suggest that option.
TheGeneral (03-10-2024)
PDCC is not needed unless you have a Targa or a Cab, its designed for "top heavy" cars.
Silver window trim while your mirrors are trimmed in high gloss black? Consider the window trim in high gloss black also, as noted above. That silver window trim is not going to sync up, IMHO. If you get the roof liner in racetek, you need the racetek sun visors too.
I wouldn't get anything listed there, I would instead consider the sport design fascias (front and/or rear, to your liking)
Save your money on the matrix, as I do not think they are yet activated in the US......
If you get PDCC you will also have to add RAS.......
1) Do the LED Matrix Headlights provide any performance value over the Standard LED (w/PDLS+) lights? Brighter? Wider? More Swivel? Anything??
2) Confirmed... PDCC requires RAS. Since we have RAS on our 991.2 Targa 4GTS, I don't see the $5K (PDCC + RAS) value in going for this combo.... Thanks for the input!
3) Night Vision Assist - Seems this forum is split as some say it works and other say not so much.....
4) Extended Range Fuel Tank. What is the latest information on the problems with this larger tank shifting and making noise??
If you don't take long trips with the car, don't get the extended tank. Most people just check that box because it's one of the few low cost options - but if you get one that rattles, and really don't need the extended range, you'll regret getting it. It's up to you to balance the pros and cons.
Interesting build.
Youve selected more cosmetic optioms (exclusive leather, gloss black calipers, black wheels) vs performance (sports package, RAS). But you also said you have 4GTS so I would assume you know what you're doing.
jbl16 (03-10-2024)
The issue with the night assist is that since the 911 has no HUD, you have to drive looking at the right side of the gauge cluster to use it.
The following 2 users liked this post by nyca:
F250to911 (03-10-2024),
silverscooby27 (03-10-2024)
The U.S. does not allow multiple light elements for headlights, so the Matrix headlights are programmed to act as a single unit. Therefore, the individual LEDs can not be activated individually to illuminate different parts of the road, as they were designed to do.
Now, there is a way to activate these afterwards, via non-Porsche sanctioned programming, but you will have to pay a guy (extra) to do this. You can search for him here in RL.
