Obnoxious to ask opinions on build!
#46
Well, with just a couple of days to spare before my freeze date, I landed on this:
https://configurator.porsche.com/porsche-code/PRCKKA97
Changed the color to Agate Grey - just wanted to go for a more subtle, elegant build.
Also added the Paldao wood to warm up the interior and add a retro look, which I think works with the Agate more than it would have with the Arctic Grey.
If I was 20 or 30 years younger, I'd go for Arctic or a brighter color.
Thanks again for all of your input!
The following 2 users liked this post by Metalblond:
Dezeinstein (02-23-2024),
user 64927802 (02-23-2024)
#47
I appreciate your input. I think you're right about the color - my concern was that Arctic is a more 'trendy' color vs a 'classic' color, since Agate has been around a while.
And Arctic is nearly the same color as my current TTRS - maybe has a more blue tone in certain lights.
Good to know about Power Steering Plus - seems like it's not necessary at all.
I do like the colored tachs and clocks, but introducing red, yellow or green into this build doesn't make sense.
Will look for other photos of the white tech to get a better idea of how it looks.
in case your are still looking for pictures of the white tach. To me it works well and have never had any problems seeing numbers as some have reported
The following 2 users liked this post by Nielsenpty:
Dezeinstein (02-24-2024),
Metalblond (02-24-2024)
#48
Very elegant and classy spec with just a little bit of sportiness brought by the RS Spyder wheels!
#49
I looked at the pictures of your build for 10 seconds and didn't go into detail as to your specs.. so two comments just on looks. I would not add any color to the tach. I think it looks great in standard form , and im not a fan of black/glass roof. I think keeping the roof the same color as the rest of the car completes the look and lines perfectly. Those are my only observations, car looks great either way. enjoy!
#51
I really like, but didnt go for the white tach, since I went for the ridiculously-priced sub second clock.
I justified it by thinking if i pay for the color on the tach or sport chrono clock, that almost covers the cost cost of the subsecond clock, which seems less distracting and looks better to me.
Is that interior yours? Looks amazing.
#52
Great build, if you are looking to trim the cost a bit, I would agree with most here that FAL and RAS are not the upgrades worth having given the cost. Most people I've talked to say RAS only really helps on track and makes daily driving sometimes feel artificial. I think if you want a track car, you would order a GTS. RAS makes tighter turning circles so if that's important, decide if its 2k worth it. The other place you could trim costs and keep the same car is 14 way instead of 18 way. My SA is pushing me away from the 18 way to 14 ways. Try to sit in both, I did and found the 14 great and the 18 felt almost as good. If you sit in both and they are the same, decide if the 1.2K is worth for the look.
In terms of color, I love Arctic Grey, I think its the right color over agate grey. I've got a GT silver on order with a similar build, going truffle brown interior, I've seen the arctic grey, love it but I'm going for that classic old man look Carrera S, with the manual. The 930 is the bomb, I skipped FAL and RAS to spend the money that I will see and enjoy sitting in the car at a red light..
I would consider adding the prep for roof rails, its 60 bucks. Last item to consider cutting if you want to trim the build cost is the front fascia. I know you said you love it, I love it too but decided not to get it. 3k for a look and you lose the active aero flaps in front. I skipped it because I decided to either go full aero package or none of it. Good luck, you can't go wrong no matter what you do.
Metalblond (02-25-2024)
#53
The thing thar scares me about RAS is that if you get it and, and as some people report, you feel the handling of the car feels artificial - can you turn the feature off? Or are you stuck with it?
#54
yes indeed the chalk/slate (with the Carbon interior and wheel. Only other thing I added besides the white tach is the leather steering column as liked how it match the contrast stitching). Exterior is aventurine green. But as it is a cab it has the stripes on the top which are in light grey and thus think the chalk/slate is a good match to tie it together
#55
Fullyield (03-01-2024)
#57
992 C4S Build
My build freeze date will be 2/27 and I've learned a lot by reading comments on build opinions. Much appreciated. My build as of today (it seems to change daily per my wife), is PRHZA490. All comments and suggestions are welcome.
#58
#59
