Crashed my c4s
Now that said, if your calculations on distance are correct, then you hydroplaned for somewhere between 11 and 20 seconds (I dont know your average speed and/or how much you slowed down) - thats simply impressive. I didnt calculate how many times I can swear in that period of time, but I bet you might have set a record.
And while most signs point to excessive speed for conditions, there is still a chance something mechanical occurred. A picture of your tires might help too.
And my best lessons in life cost me the most money - and remember, it could have been much worse.
Kuddos to you for having the guts to post this.
Regardless, I watched a buddy doing the speed limit and maybe 5 over do a very similar hydroplane in his new Z06 when we were faced with a sudden downpour (it had been just normal rain up until that point). All you need is some unbalanced section of roadway where water can pool and all of a sudden you are along for the ride.
**** happens, cars can be replaced and so long as its a learning lesson lets all move on.
The accident happened in the highway, empty road, in a straight line. I was heading up to the bridge and started raining aggressively and thats where i felt the car kick, like someone had lifted the car up. It was gliding for 300-400 m. I kept the wheel pretty much straight, didnt brake at all, did a 360 once and as the road was starting to curve i hit the concrete block divider. Speed limit is 75 mph.
Until that day, I thought I was Sterling Moss, the best rain F1 driver ever. Hard lessons to learn.
OP, you’re lucky that the officer on the scene didn’t cite/arrest you for reckless driving. This diagram doesn’t fit your claim of going 70-80MPH — you would have lost a lot more energy by the time you hit the barrier. Given the damage to the car and your diagram, it all points to you driving at “you are going to jail” speed when you hydroplaned.
Note: I’m not trying to throw shade here. You are lucky on multiple counts.
Curious on circumstances as well. A 4S should be churning through rain with no issues, especially assuming tires still like new. I would strongly recommend spending some time at PEC and spend the day practicing on the wet low fraction circle and the kick plate, no matter how good a driver you are this will help you improve your skills for situations like this.
Nope may delay it...but once you loose contact with the road surface due to water...AWD reacts like others...
i was t-boned in one of my older cars years ago and while the damage just barely missed the frame of the car and despite every effort the car just was not the same.
but maybe you live in an area that has decent body shop guys. where i live they all died off and those left do a 5/10 job at best.
but it is an accident and as the wise man says it never rains everyday!
The OP was the unfortunate victim of hydroplaning. Could've happened to anyone, including folks like Randy Pobst, Chris Harris, Ken Block, etc.
Maybe the OP could learn to be more careful generally and perhaps defensive driving lessons (the stuff you read about in your DMV brochure) may help, but track day driving lessons in and of themselves would not have prevented this from happening, and will not prevent it from happening again in the future.
I will not answer why or where but I will share my experience for educational purposes.
I hydroplaned my 992 T at 95 mph. It was 60 degrees and drizzling when I hit standing water. ~6k mi on Eagle 1s. Wet mode. The rear wobbled three times in each direction before settling.
I attribute two things to zero consequence and no drama:
1. I did several years of autocross in all weather conditions including rain and snow.
2. The 992 and specifically its Porsche Torque Vectoring system.
I maintained my speed, counter steered lightly and smoothly, and most of all, I didn't panic. This I believe helped greatly, but what I believe mostly saved my *** was PTV. I could feel the rear wheels doing what felt like light ABS counter braking, and as a result the rear wobble was cut short, throwing the rear to the opposite direction but with less force each time until the car regained stability and traction. It all happened in a flash and I'm thankful for both my training and, for once, for the nannies in these newer cars. The 992 is an incredibly safe and capable car that inspires confidence and doesn't bite too hard when you get in trouble.
Glad OP is safe and no one hurt.
Godspeed,
L76
I notice that the spoiler is raised. I assume it wasn't at the time of the accident, so it "deployed" when the wall hit you? This points additionally to electronic damage, please don't ask me how I know, my 992C4S has been dead for 3 months this Tuesday.
The day it died when trying to start it, the lights went out and the spoiler raised. I'm a few days short of calling it quits and invoking the Lemon Law. Long story, not relevant etc. But just wanted to place this on the table that in addition to any structural damage, electronic damage or total shutdown (refuses to start mentioned) due to impact also occurred. Whether BCM2, DME or other systems will need to be replaced. GL
siberian
Airbags are primarily something that protects occupants during front end collisions. From my experience, they're only particularly effective for the initial hit. If you get hit multiple times, they don't do much if anything to protect you. I walked away from an accident where I hit a black Toyota land cruiser that was parked in the exit only lane (inexplicably, not the shoulder) with no lights on, in the pitch black night. I was going 85MPH (flow of traffic). The collision was unavoidable. I didn't the see the Toyota until the headlights of my Chevy Cobalt rental revealed it. I turned ever so slightly in an attempt to avoid the hit. The passenger side front took the brunt of the hit. If I had a passenger, they likely would have been killed instantly -- it was all jagged metal. On the driver side, the floor buckled up with my legs luckily popping up on each side of the steering wheel. Glass was everywhere. After spinning several times, the Cobalt came to a stop perpendicular to the flow of traffic with the passenger side facing the oncoming traffic. Then, a tractor trailer hit me and ripped the back half of the car off. The airbags had already gone off so my body was hitting the hard bits at that point. The car was spun around again, facing oncoming traffic when it came to a stop. Thankfully, the oncoming traffic came to a stop as well. I took inventory of my body. I was soaked in my own blood with glass in my eyes, face and mouth. At this point, there were bystanders on the scene including witnesses that saw everything. Someone started shouting at me that there was gas everywhere. I elbowed the drivers door open and got myself to the guard rail. The first trooper that arrived on the scene asked "Where's the driver?" I raised my hand and called his attention. The first words out of his mouth were "You should be dead!"
Long story short, airbags only help you on the first hit. 😜
Other fun notes, the Toyota had come to a stop, because they had a flat tire and didn't know what to do. A whole family was in that car when it got punted by the Cobalt. Thanks to plenty of witnesses, they were found at fault AND cited on the scene. This was very helpful for the insurance adventure that followed. Heck, the insurance company of the truck tried to go after me for damages to their insured's vehicle, which was entertaining. Best part? Enterprise called me about a month later asking when I was going to return the rental car. From this experience, I know that I have all of the insurances, etc necessary for a totaled rental car. Whenever a rental car person gets pushy with me on their plans and waivers, I tell them that I totaled one once and it's not a big deal. LOL
On the PTSD front, it took a couple of years for me to feel truly comfortable driving a car at night again. Even video game crashes were pushing buttons in my brain for a while. That stuff is no joke.
siberian
siberian
