Carrera T vs. S vs. GTS
The Game changer for me is the Suspension set-up for the GTS. It really locks the car down and is quite noticeable. It is far from harsh and it reminds of my 991.2 GT3.
I think if one wants a Cabrio that drives/handles like a coupe with (0) body roll the GTS is the route to go. It was precisely the reason I went with the GTS Cabrio plus it tends to hold Value(GTS) better in the long run
And I do not believe you can feel the difference in power. I think the removal of some of the sound deadening in the GTS makes you think it feels faster because the exhaust is more pronounced
The following 4 users liked this post by jhenson29:
The following 5 users liked this post by detansinn:
bobert75 (01-29-2024),
defiant2 (01-28-2024),
Drstimpy2! (01-28-2024),
edofloat (01-29-2024),
incoming992s (01-31-2024)
I was thinking about it, and there is so much similarity between the trims that I wonder if Porsche has a "binning" process when it comes to which cars get what?
What I mean / For example:
Parts are evaluated for quality and assigned A/B/C grade:
GTS only gets "A grade" parts
S gets "A/B grade" parts
Base / T gets "A/B/C grade" parts
Does anyone know if this type of thing is done at any level of production?
alexb76 (01-30-2024)
txpackers (01-29-2024)
While my experience is only with the S and GTS test drives, the differences were quite minor on the road in perceived performance. The most notable was the suspension, with the S handling the city street bumps more comfortably than the GTS (2 cars driven, with and without PDDC). I attribute part of that to tire pressures through, with GTS very high (45+ rear), and I don't think the salesman would have appreciated me lowering them! The GTS did sound better given the removal of additional insulation.
After that it all comes down to customization. I settled on a GTS order, although probably overdid the options driving quite the build delay (I'd go simpler next time).
Most of the customer specific customization is cosmetic...choices in leather colors, stitching, exterior lights etc. wouldn't really make a big difference in the number of parts. Of the tens of thousands of parts an ICE vehicle has, vast majority are from the mechanical bits (i.e. chassis and powertrain). Those parts amongst the Carrera line-up are mostly the same with subtle differences in turbos, suspension tuning, etc. I'm referring to just the Carrera models and not including the Turbo or GT models as those models obviously have far more differences mechanical wise.
Care to share some insider info on how it does work? Is every part on a "pass or fail" type of QC for all cars, or does some kind of parts sorting between trims happen at all?
It's a lot that's for sure. Molds wear, tools dull, etc so It seems reasonable to wonder if the best stuff gets put aside for the highest trims/specs.
This is pretty much how it's done in the semi conductor world.
