Window roll down issue
Hi all,
Merry x-mas!!
I have an issues with the auto roll down function when unlocking the car and opening the driver side door.
In my case the window goes down, but it rubs minimally on the textile roof on this side.
The passenger side is perfect and not having this.
Does anyone know how and whether the position of the door window height can be adjusted on the 992?
For example, like 0.1 inch downwards after opening!
Thanks upfront
Merry x-mas!!
Thanks upfront
You have a cab or Targa? There was another member that posted pictures of wear to their Targa top from this issue. I know the Auto up/down can be calibrated to their full stops by the user but I don't think the limits of the small scroll up/down (for opening and closing the door) can be calibrated by the user. Definitely take it to the dealer.
Mine intermittently doesn’t go down far enough. That or it goes back up early. I’m not sure. But I’ve had a number of times that the door wouldn’t close because the window was up too high. I had to lower it with the button, close the door, and then raise it. But that sounds like a different issue.
I’ve had this happen twice on my targa passenger door. No solution and not a consistent problem.
The following 2 users liked this post by CapitanoAR:
Jeff Whitten (03-23-2024),
OMTarga4S (04-13-2024)
Anyone have window that wouldn't move at all? Mine got stuck the other day and wont go up nor will it move when the door opens. 24 Targa.
